Proof of vector property in space
  • Level: Undergrad
  • Thread starter chwala
    Proof
9 replies · 3K views · last reply
chwala
TL;DR
See attached
Typeset proof showing the commutativity of the dot product of vectors u and v in three dimensions, then a chain of equalities showing c(u · v) = (cu) · v = u · (cv) = (cu) · v using component expansion.
My interest is on the associative property; is there anything wrong of showing and concluding proof by;
##c(\vec u⋅\vec v)=(c⋅\vec v)⋅\vec u.##
or are we restricted in the prose?
Your equality contains three different types of multiplications: scalar by scalar; scalar by vector and a vector by vector. I do not think that it makes sense to call this "associative property"
Did you understand my question? I am going through the pdf notes and my question is specifically on: the associative property.
##c(\vec u⋅\vec v)=(c⋅\vec u)⋅\vec v##
as indicated on my pdf notes...
Unless, you are of the opinion that the notes are not correct.
i am asking if the proof could be allowed to take this route
##c(\vec u⋅\vec v)=(cv_1, cv_2, cv_3)⋅(u_1,u_2, u_3)##
to end up with,
##c(\vec u⋅\vec v)=(c⋅\vec v)⋅\vec u##
What is c a scalar or a vector?
On the LHS you use c as a scalar multiplied by the scalar inner product of U and V
But on the RHS, you've dotted c with the U vector.
Since there is no hat on c then it must be a scalar and the RHS operator usage is confusingly wrong.
I put arrows on ##u## and ##v## to indicate that they are vectors...if that is not correct then you may guide me. I did not get it right on latex, sorry for that confusion and i ought to have clearly stated that ##c## is a scalar and ##u,v## are vectors... now can we focus on my question? Thanks...
Amended
wrobel said:
what's this?
Amended. The correct position is as follows:
to end up with,
Yes that's completely fine due to your proof above it of the commutative property.
@chwala, for information, part of the confusion is that you have written expressions containing ##c⋅\vec u## and ##c⋅\vec v##. But these are wrong.
##c## is a scalar.
##⋅## in this context is the dot (inner) product of two vectors.
##\vec u## and ##\vec v## are vectors.
##c⋅\vec u## should be ##c\vec u##
##c⋅\vec v## should be ##c\vec v##
For example, in Post #8 you wrote "##c(\vec u⋅\vec v)=(c⋅\vec v)⋅\vec u##". This is wrong and should be written as ##c(\vec u⋅\vec v)=(c\vec v)⋅\vec u##.
Edit: @jedishrfu already pointed out (Post #5) this problem.
