Proof of Wye-Delta Transform Doesn't Make Sense
  • Thread starter Thread starter yosimba2000
    Proof Transform
The forum discussion centers on the confusion surrounding the equivalent resistance between terminals 1 and 2 in a circuit involving resistors R1, R2, and R3. The original claim that R1 and R3 are in series is challenged, as the presence of R2 suggests that the currents through R1 and R3 differ. Participants clarify that the equivalent resistance R12 is determined by the configuration of the resistors, and R2 does not affect the calculation when considering only terminals 1 and 2. The discussion emphasizes the importance of understanding equivalent resistance and suggests practical methods for verification, such as calculations or simulations.
  • Understanding of basic electrical circuit theory
  • Familiarity with equivalent resistance concepts
  • Knowledge of series and parallel resistor configurations
  • Experience with circuit simulation tools or ohm-meters
  • Learn how to calculate equivalent resistance in complex circuits
  • Explore circuit simulation software like LTspice or Multisim
  • Study the Wye-Delta transformation in electrical circuits
  • Practice using an ohm-meter to measure resistance in various configurations
Electrical engineering students, circuit designers, and hobbyists interested in understanding resistor configurations and equivalent resistance calculations.
yosimba2000
In the picture taken from my book, in the bottom red box, it states that the equivalent resistance seen between terminals 1 and 2 is R1 + R3, implying R1 and R3 are in series.
But clearly, there is a third resistor R3 at the same node where R1 and R2 meet. Then that means R1 and R3 cannot be in series. Then why does the book state the equivalent resistance is R1+R3?
You need to understand the meaning of equivalent resistance. Here, R12 is the equivalent resistance between 1 and 2. This means if there were a source connected between 1 and 2, it would "see" the resistance of the network as R12. Hence, R1 and R3 are in series and R2 is redundant.
I don't think that's correct, that they're in series. If they were in series, Both R1 and R3 would have the same current passing through them. But if you pass a current downwards from R1, and downwards from R2, R3 gets the addition of both currents, not just from R1. No matter how I arrange the currents, I can't see any way for resistors R1 and R3 to have the same current, and hence be in series, unless R2 is disconnected.
When they refer to the equivalent resistance between terminals #1 and #2, that implies that the are no connections to the other two terminals. Therefore, for that euivalent resistance, resistor, R2 is not involved at all. The only path for current to flow would be through resistors, R1 and R3.
@yosimba200 If you have doubts about this then you could always put in some values, go through the calculations and see what you get. If the answers agree then, at least, you can believe the system works ('cos it does). You could then be 'emotionally OK' with the theory; intuition can often get in the way of understanding.
What I am suggesting involves putting a voltage source on the left and a resistive load on the right and working out the current into the load (in both cases, using the formulae to get the WYE values from the DELTA). If you don't like the sums then use a simulation to get your answer (or some resistors and a soldering iron :smile:)
Wait a minute...
The resistance measured in by the probes of an ohm-meter calculate only the resistors that are connected between the probes, right?
yosimba2000 said:
Wait a minute...
Yes. It measures the equivalent resistance between those two points.
yosimba2000 said:
Wait a minute...
I'm not sure precisely what you mean by that but, in a complex circuit, the Ohmmeter will see all the paths through the circuit and not just the 'obvious' path.
13K
  • · Replies 17 ·
12K
  • · Replies 20 ·
10K
