Proofing the Relation of u, v, x, y, a
4 replies · 2K views
Yankel
Hello,
I need to do this proof here:
I tried but didn't get what I wanted, so I was re-thinking the whole thing.
If I say u=y+ax and v=y-ax, should I do something like (dz/df)*(df/du)*(du/dx)+...?
Because I tried just with u and v (without f and g), and I got almost what I wanted, with a little minus away from proofing, but I think I got it wrong from the start...
Yankel said:
Hello,
https://www.physicsforums.com/attachments/2008
Soppose to have to solve the second order PDE...
$\displaystyle z_{x x} = \frac{1}{a^{2}}\ z_{y y}\ (1)$
Substituting the x and y variable $u = x - a\ y$, $v=x + a\ y$ and applying the chain rule You arrive to write from (1)... $\displaystyle z_{x x} = z_{u u} + 2\ z_{u v} + z_{v v}$
$\displaystyle a^{2}\ z_{y y} = z_{u u} - 2\ z_{u v} + z_{v v}\ (2)$
... and the means that...
$\displaystyle z_{u,v} = 0\ (3)$
It is easy to see that the solution of (3) is...
$\displaystyle z (u,v) = f(u) + g(v) = f( x - a\ y) + g(x + a\ y)\ (3)$
Kind regards
$\chi$ $\sigma$
The chain rule tells us that:
(1) $$\frac{\partial z}{\partial x}=\frac{\partial z}{\partial f}\frac{\partial f}{\partial x}+\frac{\partial z}{\partial g}\frac{\partial g}{\partial x}$$
Let $t$ be the variable by which $f$ and $g$ are defined.
The chain rule also tells us:
(2) $$\frac{\partial f}{\partial x}=af'(t)$$
(3) $$\frac{\partial g}{\partial x}=-ag'(t)$$
And so we have:
$$\frac{\partial z}{\partial x}=a\left(f'(t)\frac{\partial z}{\partial f}-g'(t)\frac{\partial z}{\partial g} \right)$$
Now, differentiating this with respect to $x$, we find:
$$\frac{\partial^2 z}{\partial x^2}=a\left(f'(t)\frac{\partial^2 z}{\partial f^2}\frac{\partial f}{\partial x}+af''(t)\frac{\partial z}{\partial f}-g'(t)\frac{\partial^2 z}{\partial g^2}\frac{\partial g}{\partial x}+ag''(t)\frac{\partial z}{\partial g} \right)$$
Using (2) and (3), we find:
$$\frac{\partial^2 z}{\partial x^2}=a^2\left(\left(f'(t) \right)^2\frac{\partial^2 z}{\partial f^2}+f''(t)\frac{\partial z}{\partial f}+\left(g'(t) \right)^2\frac{\partial^2 z}{\partial g^2}+g''(t)\frac{\partial z}{\partial g} \right)$$
Now you may proceed similarly to show that:
$$\frac{\partial^2 z}{\partial y^2}=\left(f'(t) \right)^2\frac{\partial^2 z}{\partial f^2}+f''(t)\frac{\partial z}{\partial f}+\left(g'(t) \right)^2\frac{\partial^2 z}{\partial g^2}+g''(t)\frac{\partial z}{\partial g}$$
I find this easier conceptually without Liebniz:
$z_x = f'(y + ax)(a) + g'(y - ax)(-a)$
$z_{xx} = (a)f''(y + ax)(a) - (a)g''(y - ax)(-a) = a^2(f''(y + ax) + g''(y - ax))$
$z_y = f'(y + ax)(1) + g'(y - ax)(1)$
$z_{yy} = f''(y + ax) + g''(y - ax) = \dfrac{1}{a^2}z_{xx}$
Deveno said:
I find this easier conceptually without Liebniz...
I did too, but felt the OP was likely supposed to invoke ol' Liebniz. I'm glad you posted it though, as an easier alternate method. (Yes)
