Prooving a statement with a Lemma
  • Thread starter Thread starter alexk307
11 replies · 4K views
alexk307
Using the lemma below, prove that if two integers divide each other, then they are equal
Lemma: If the product of two integers is 1, then the integers each equal 1.
Very lost here, I can format the proof but I don't know where to start it. Also, isn't the lemma false? If a*b = 1, then a and b equal 1. What about 3/4 * 4/3 = 1? or 2/3 * 3/2 = 1?
Ah, but you're forgetting the hypothesis of the lemma. What's the hypothesis? The hypothesis is assumed to be true so...
Once you understand the lemma, what does it mean for one integer to divide another integer?
3/4 and 4/3 aren't integers, nor are 2/3 and 3/2.
Oh man, that's embarrassing... Thanks
okay so,
I assumed that a and b are both integers and that a/b = 1.
Should I also assume that c*d=1 according to the lemma that if cd=1 then c and d are 1?
alexk307 said:
okay so,
Start with the hypothesis of what you're trying to prove. Using math terms, what does it mean if a divides b? b divides a?
Okay, so if a divides b, then a = bq, where q is the multiplier, also there is no remainder.
so I see that a = bq and b=aq
solving for q... q^2=1 and q=1
I don't know if I'm onto anything by saying q*q=1, and the lemma are related.
just got it I think. because q*q = 1, q must equal 1. Therefor a = bq and b = aq can be reduced to a=b and b=a.
Not quite. It's true that a = bq, where q is an integer. However, you cannot say b = aq. It could be a different integer, so the simple solution is to make b = ar, where r is an integer.
So now that you have the two equations:
a = bq
b = ar
What can we do?
oh okay so a=bq and b=ar solving for then rq=1.
So I had the right idea, but I can't say that they're both able to be divided by the same integer, but that rq=1
and then r and q both equal 1, so a=b and b=a.
You got it.
