Does Propagation of Uncertainties Work with Only One Variable?
Propagation of uncertainties using partial derivatives is applicable even when dealing with a single variable. The method remains valid as it calculates how uncertainties affect the outcome based on the sensitivity of the function to changes in that variable. While the complexity may decrease with only one variable, the fundamental principles of uncertainty propagation still hold true. This approach allows for accurate quantification of uncertainty in measurements and calculations. Therefore, it is confirmed that uncertainty propagation works effectively with just one variable.
Panphobia
Just a quick question, would propagation of uncertainties with the partial derivatives still give the right answer when you only have one variable?
Sure.
