Propane phase change in a container
7 replies · 3K views · last reply
Kirmandarren
If I had a container containing 10 bara of nitrogen, and pumped in liquid propane at room temperature would the propane boil?
If I carried out the same experiment but this time at 5 bara, what would be the temperature of the material once the propane had completed its phase change i.e would it drop to around 0C and stop boiling, would the liquid then just evaporate into the vapour space?
Room temperature is what? "bara" is what?
Take room temperature as 25C, I'm using bar absolute pressure rather than gauge
The boiling point at 10bar is approximately 25C. The vapour pressure would therefore also be 10 bar at 25C.
Is this an isothermal process? Adiabatic?
adiabatic process, I'm aware that there isn't enough info to answer the second question. What I was getting at is: the propane liquids boiling point changes due the the pressure above it no matter what it vapour/gas consists of. Once the temperature drops below its boiling point, evaporation takes over. Also if all the propane turns to vapour (not saturated with vapour), by increasing the pressure by addition of more nitrogen (volume remains constant) the propane will not condense, lowering the temperature is the only way to condense the propane. Is the above logic correct?
Yes
