Properties of fields in quantum field theory
The discussion centers on the properties of fields in quantum field theory, specifically regarding the energy-momentum tensor and the interpretation of field derivatives. It clarifies that the notation φ with a dot (or φ') represents the rate of change of the field at a specific point in time, not the velocity of the field itself, which is analogous to wave motion in a rope. The conversation also addresses misconceptions about fields having mass, explaining that while fields can have energy, this does not imply they possess mass in the classical sense. Instead, mass is a form of energy, and fields are better understood through Noether's theorem, which relates symmetries to conserved quantities. Overall, the discussion emphasizes the nuanced understanding required in quantum field theory regarding the nature of fields, energy, and mass.
space-time
I have been studying quantum field theory and I am currently in the Lagrangian field theory chapter in my book. Now it says that the energy momentum tensor is as follows:
Tμν= [∂L/∂(∂μφ) * ∂νφ] - δμνL
Note: I am using L to symbolize Lagrangian density and not just Lagrangian since the latex box doesn't have the curly L in it. Those two indices on the term on the right go to the Kronecker delta, not to the L.
It follows up by saying that
T00 = [∂L/∂φ' * φ'] - L (in the book, they have φ with a dot over it instead of φ' )
Now I just want to verify some things:
Does φ with a dot over it (or φ' ) refer to ∂φ/∂t ?
If so, then this would be the velocity of the field correct, since it is the first time derivative? I ask this because unlike in the classical mechanics example problems that the book gave (where I was just dealing with position functions of time), fields φ(x,t) are functions of both time and space.
Also, how does a field itself have a velocity if it permeates all of space? I could see how the particles that are generated from fluctuations of said field have a velocity. How does the field itself have a velocity? Does velocity for a field refer to how fast the particles generated from that field move or how fast the field's fluctuations are? Is it something else?
Finally, how can a field itself have mass? If you plug a Lagrangian density into the Euler Lagrange equations for some given Lagrangian densities, then you sometimes get mass terms in the equations of motion that you derive? Once again, I see how a particle that comes from a field has mass, but I don't see how the field itself has mass (example, I see how the gluon has mass, but how does the strong field have mass?)
As to the last question about the fields having mass, I would suppose (if I am incorrect please correct me) that since the fields have energy, they must also have a mass equivalent to that energy.
That's not true. Its a VERY VERY common misconception and anyone that believes can be excused. E=MC^2 says mass is a form of energy. Energy comes in a lot of forms eg EM field energy - mas is simply one of those forms. It does not imply energy is a form of mass.
Thanks
Bill
bhobba said:
That's not true. Its a VERY VERY common misconception an anyone that believes can be excused. E=MC^2 says mass is a form of energy. Energy comes in a lot of forms eg EM field energy - mas is simply one of those forms. It does not imply energy is a form of mass.
Thanks
Bill
May you please PM some of the details, or refer me to a section in a book or even a Wikipedia article so that I can learn more about what you're saying?
Yes
No. Its the rate of change of the field value at a specific point. Think of a stretched rope with waves - the derivative gives a rate of change of the height of a little element of the rope - that's not the velocity of the waves of the rope.
The same way waves in a rope have a velocity.
In QFT they can - but I will let someone more conversant in that subject explain why. In classical field theory the field doesn't have mass - it has energy via Noethers theorem and the modern definition of energy - but not mass.
Thanks
Bill
Its simple logic.
The modern definition of energy is via Noether's beautiful and deep theorem:
http://www.sjsu.edu/faculty/watkins/noetherth.htm
Although you may not have seen it done this way the correct derivation of E=MC^2 uses that:
http://fma.if.usp.br/~amsilva/Livros/Zwiebach/chapter5.pdf
It proves the energy of a free relativistic particle at rest is MC^2. It does not prove energy in a general sense has mass - indeed from the modern definition based on Noethers theorem it makes no sense.
The reason its a very common error is people are often very loose about reasoning with it - even some experts who should know better.
However if you want to pursue it start a thread in our relativity sub-forum.
Added Later
The following may also help:
http://www.quora.com/Does-energy-have-mass
Thanks
Bill
Likes vanhees71
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 31 ·
