Properties of mixed partial derivatives
The discussion centers on the properties of mixed partial derivatives, specifically the commutation of partial derivatives. The user wefoust seeks clarification on transitioning from the expression (\frac{\partial}{\partial x}\frac{\partial v}{\partial t}-\frac{\partial}{\partial y}\frac{\partial u}{\partial t}) to \frac{\partial}{\partial t} (\frac{\partial v}{\partial x} - \frac{\partial u}{\partial y}). It is established that partial derivatives commute under certain conditions, specifically when the second partial derivatives are continuous, as referenced in Schwarz's theorem. The conversation highlights the importance of understanding these conditions to avoid overgeneralization.
  • Understanding of mixed partial derivatives
  • Familiarity with Schwarz's theorem
  • Knowledge of continuity in calculus
  • Basic proficiency in LaTeX for mathematical notation
  • Research the conditions under which partial derivatives commute
  • Study the implications of discontinuous second partial derivatives
  • Explore the applications of Schwarz's theorem in multivariable calculus
  • Learn how to properly format mathematical expressions using LaTeX
Students and professionals in mathematics, physics, and engineering who are dealing with multivariable calculus and the properties of derivatives.
wefoust2
Hi, I am sort of hung up with a particular step in a derivation, and this has caused me to ponder a few properties of partial derivatives. As a result, I believe I may be correct for the wrong reasons. For this example, the starting term is
I want to go from the above term to
I am a little confused how this is done. I am not sure if you can "factor" out the \frac{\partial}{\partial t} or not. I thought about simply rearranging the partials, but I don't think I can assume the function is smooth or symmetric. Any help or insight you can provide will be appreciated.
Thanks,
wefoust
Well, partial derivatives commute, so
\frac{\partial}{\partial x} \Big(\frac{\partial v}{\partial t}\Big)=\frac{\partial^2v}{\partial x \partial t}=\frac{\partial}{\partial t}\Big(\frac{\partial v }{\partial x}\Big)
from there you can factor out the time derivative.
Doesn't that require the continuity of the second partial derivatives in order to be true in general? It seems to me that OP explicitly stated that not enough is known about the function to guarantee that?
Hi guys,
Thank you very much for you input so far! I've looked up some more info based on the links and terms you all have used, and I feel that I am getting descent understanding about the property. It seems that assuming all partials commute is a bit of an overstatement. In most cases the partials should commute, but there do exists special cases, as when the 2nd order is not defined or continuous (this holds for both ways as in Fxy or Fyx).
Again, thanks for the help, and let me know if you come across something more convincing.
  • · Replies 16 ·
