Proportionality statements in physics
The discussion revolves around deriving a linear equation from a set of values for Fc and F, where Fc is proportional to 4√F. The user attempts to use the slope of 3/0.02 to create the equation but finds it ineffective. Another participant suggests incorporating a y-intercept into the equation, providing a linear equation of Fc = 177√[4]{F} - 165. Additionally, there is a critique of the original slope calculation, indicating it may be underestimated for the given data points. The conversation emphasizes the importance of accurately determining the slope and including a y-intercept for proper linear representation.
123aw
A chart has values of Fc (dependant): 10, 15, 20, 25, 30, respectively. The independant variable, F, has values 0.98, 1.07, 1.16, 1.32, 1.50, respectively. These values form a root graph.
Fc is proportional to 4√F, this is the proportionality statement allowing me to make the graph linear. The slope of the linear is 3 / 0.02.
How can I derive an equation for the linear using the slope and values I have if the slope is the constant?
my attempt is[/B]
4√F × constant (slope)
however it does not work
Have you considered adding y-intercept to your equation? I plotted your data and obtained the linear equation F_c = 177\sqrt[4]{F}-165. Also, I think the slope you have (3/0.02) is too underestimated for your data points.
13K
  • · Replies 17 ·
21K
