Prototype 3-Wheeled Car Steering Mechanism
  • Thread starter Thread starter Moneim230
    Mechanism Steering
The discussion revolves around designing a steering mechanism for a prototype 3-wheeled car, specifically focusing on the stability and maneuverability of the vehicle. Participants explore various steering mechanisms suitable for a configuration with two rear wheels and one front wheel, considering both manual and automated solutions.
  • Some participants suggest tilting the axis of the front wheel for steering, similar to a bicycle, if there is a single drive to both rear wheels.
  • Others propose using a caster wheel at the front and controlling the speed of the rear motors for steering if separate drives are available.
  • A participant mentions the possibility of using a small motor with a sprocket and chain system to control the steering direction, requiring programming for control.
  • Another idea involves using a string attached to a fixed point to steer the front wheel, which would create a circular motion around the fixed point.
  • Some participants discuss the feasibility of using two motors at the rear for better control and suggest that this approach may require more complex programming compared to a single motor setup.
  • One participant compares the proposed steering mechanism to the hydraulic actuators used in aircraft, noting the advantages of hydraulic systems for force and efficiency.
  • There is a suggestion to mount the front wheel on a shaft with strings to allow for steering by pulling from either side, though this is described as potentially impractical.
  • A participant questions the complexity of programming required for using two motors versus a single motor and sprocket system, emphasizing the need for synchronization in the dual motor setup.
  • One participant proposes an alternative configuration with two front wheels and one rear wheel, referencing historical designs like the Morgan trikes.
Participants express differing opinions on the best steering mechanism, with some favoring the simplicity of a single motor and sprocket system, while others advocate for the benefits of using two motors at the rear. The discussion remains unresolved regarding the optimal approach, as various models and ideas are presented without consensus.
Participants mention the need for programming skills and budget considerations, which may influence the choice of steering mechanism. There are also references to the mechanical advantages and limitations of different configurations, but these aspects remain unresolved.
Individuals interested in robotics, vehicle design, or mechanical engineering may find the discussion relevant, particularly those exploring innovative steering solutions for unconventional vehicle configurations.
Moneim230
hello all
i'm creating a prototype for a 3 wheeled car ( 2 wheels at the back & 1 wheel in the front ) motor with the 2 wheels in the back
i want to test its stability so i want it to move in a straight line then take a curve
can someone suggest a simple mechanism for the steering (from the single wheel in the front) ?
If you only have a single drive(single drive to both wheels), you need to tilt the axis of the front wheel, like a bike.
If you have separate drives for both rear wheels, just use a castor at front, and control the speed of both motors for steering.
for the first suggestion : will i need to do it manually ? is there any mechanism that can make it move in a straight line then take a curve (tilt the axis) ??
thanks for help ^_^
Actually it would be quite easy to do. I'm assuming you have access to motors. a small motor with a sprocket on the drive shaft and a chain attached to a sprocket on the wheels shaft and you could have it steer either direction you wanted. (this requires some programming if you want to control steering)
The other option is to rig it with a string to a fixed point, when the string goes taught itll jerk the wheel in one direction. but then it'll go in a circle around this fixed po9int until you shut it off or you run out of string!
What else??
you cane make a link attached to the shaft of the front wheel, now pull it back to steer one way, push it to steer the other way.
I didn't get you clearly bear, won't it make it a one way process??
Anyways, 230, one more idea, mount your front wheel on a shaft, and tie a string to its both ends(wheel is in the middle), now pull this string from one side to steer, & pull from the other side to steer other. Pretty stupid, huh?? You need two exactly same motors(small ones) with each string wrapping over each shaft. Rotate the motors in opposite directions, so while you pull one side, other side will be unwrapping & vice versa.
Actually, this is how B737 steers, with hydraulic actuators in place of strings.
To Ank
Well the second way would, but if he is just testing stability in the process of turning, it would work. The first way is similar to your B737 idea but it only requires the programing and control of one motor. They use hydrolics on planes because you can get more force and they use a hydrolic system to control the flight elements. It would be simpler and more efficent to use one motor with a chain and sprockets.
I suggested the rope and fixed point because i wasn't aware of any programming skills or circuitry skills which will be required if he is going to want to control the motor apart from on and off. If 230 could let us know of his capabilities and budget we could give more suitable ideas.
i think the idea of 2 motors at the back is better & easy so i'll use it
Oh yes, right bear, using a sprocket makes it equivalent to a link.
Is this for some robotics contest?? If yes, differential drive is your best bet, while for bigger systems, this type of steering is a wastage of energy.
Best of luck.
Actually it reuires much more complex programing then using a single motor and chain.
For that style you have to program the motors to run in opposite and be synchronized.
It will require programming for two motors. Since it has two motors it is also more expensive.
My idea requires the programming of one motor either clockwise or counter clockwise.
It also allows for mechanical advantage so you can use a smaller motor. With ank's concept you cannot change the diameter of the drive shaft or the driven and so if you motor is not strong enough you need a new motor instead of a larger sprocket.
why not just put the two wheels up front
and use one in the back
if you must have three wheels
like the old morgan trikes
  • · Replies 16 ·
9K
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 58 ·
9K
  • · Replies 17 ·
