Prove 5|(3^(3n+1)+2^(n+1)) for every positive integer n.
  • Thread starter Thread starter Tsunoyukami
    Integer Positive
The discussion revolves around proving that \(5|(3^{3n+1}+2^{n+1})\) for every positive integer \(n\), as presented in Exercise 11.8 from "Mathematical Proofs: A Transition to Advanced Mathematics" (3rd edition) by Chartrand, Polimeni & Zhang. The initial approach involved mathematical induction, where the user successfully demonstrated the base case for \(n=1\) and assumed it holds for an arbitrary positive integer \(k\). The proof was completed by manipulating the expression \(3^{3(k+1)+1}+2^{(k+1)+1}\) and utilizing the assumption that \(5|(3^{3k+1}+2^{k+1})\) to conclude that \(5|(3^{3(k+1)+1}+2^{(k+1)+1})\).
  • Understanding of mathematical induction
  • Familiarity with divisibility rules in number theory
  • Ability to manipulate exponential expressions
  • Knowledge of modular arithmetic
  • Study advanced techniques in mathematical induction
  • Explore divisibility proofs in number theory
  • Learn about modular arithmetic and its applications
  • Investigate other methods of proof such as contradiction or contrapositive
Mathematics students, educators, and anyone interested in number theory and proof techniques, particularly those focusing on divisibility and induction methods.
Tsunoyukami
"Prove ##5|(3^{3n+1}+2^{n+1})## for every positive integer ##n##." (Exercise 11.8 from Mathematical Proofs: A Transition to Advanced Mathematics 3rd edition by Chartrand, Polimeni & Zhang; pg. 282)
I'm having difficulty solving this exercise. My first thought was to use induction but I get stuck with an expression that I can't seem to manipulate into the required form. The next thing I tried was considering cases (when ##n## is even and when ##n## is odd) but once again I get stuck.
Can anyone suggest another method of proof?
I feel that induction should work out for me despite my difficulties. As such, I will explain what I've done so far. If you would like to see work I describe but do not include below let me know and I'll include it.
First I showed that this expression holds for the case ##n=1##. I assumed this holds for some arbitrary positive integer ##k##. Now I wish to show that ##5|(3^{3(k+1)+1}+2^{(k+1)+1})##.
From here I tried working with the expression ##3^{3(k+1)+1}+2^{(k+1)+1}##:
##3^{3(k+1)+1}+2^{(k+1)+1}=3^{3k+3+1}+2^{k+1+1}=3^{3k+4}+2^{k+2}=3^{3k} \cdot 3^4 + 2^{k} \cdot 2^{2}=81\cdot3^{3k}+4\cdot2^{k}##
This is where I get stuck - I don't know how to massage this equation to show that 5 divides it.
Write that as ##3^{3(k+1)+1}+2^{(k+1)+1}=27*3^{3k+1}+2^{k+1}##. Note 27=25+2.
Thanks so much for the hint!
So we can write:
##= 27 \cdot 3^{3k+1}+2\cdot 2^{k+1}##
##=(25+2)\cdot 3^{3k+1}+2 \cdot 2^{k+1}##
##=25 \cdot 3^{3k+1} + 2 \cdot 3^{3k+1} + 2\cdot 2^{k+1}##
##= 25 \cdot 3^{3k+1} + 2 \cdot (3^{3k+1} + 2^{k+1})##
By assumption we know that ##5|(3^{3k+1} + 2^{k+1})## so we can write ##(3^{3k+1} + 2^{k+1})=5x## for some integer x.
Then we have
##=5(5\cdot3^{3k+1})+5\cdot2x##
##=5(5\cdot3^{3k+1}+2x)##
Since ##5\cdot3^{3k+1}+2x## is an integer, we conclude that ##5|3^{3(k+1)+1}+2^{(k+1)+1}##.
So we can write:
Then we have
Right. You definitely want to keep ##3^{3k+1} + 2^{k+1}## in the answer somehow because you know it's divisible by 5. And splitting the factor up becomes pretty obvious once you've seen the trick.
  • · Replies 30 ·
