Prove a complex expression = 1, if log of the complex terms are equal
15 replies · 3K views · last reply
Govind_Balaji
If [itex]\frac{\log x}{b-c}=\frac{\log y}{c-a}=\frac{\log z}{a-b},[/itex] prove that [itex]x^{b+c-a}.y^{c+a-b}.z^{a+b-c}=1[/itex]
I solved a question similar to it in a way. So I tried this in the same way. The only difference between the two questions is that except a,b and c, the denominators are also x, y and z.
I didn't know if it would work.
So I tried like this.
Let [itex]m= b-c, n= c-a[/itex]then [itex]a-b=-(m+n)[/itex]
By cross multiplication, I got
[itex]z^m=x^{-(m+n)}\\z^n=y^{-(m+n)}\\x^n=y^m\\\\\Rightarrow z=1/xy, x=1/yz, y=1/xz[/itex]
In my old question it was to prove [itex]x^x.y^y.z^z=1[/itex]. So I substituted easily.
I am struggling to substitute here.
So I tried writing [itex]x^{b+c-a}.y^{c+a-b}.z^{a+b-c}[/itex] it easier by using m and n.
[itex]x^{b+c-a}.y^{c+a-b}.z^{a+b-c}=x^{2n+m+a}.y^{a-m}.z^{a+m}[/itex]
I am struggling then after. Can anyone give me a hint.
Try working backwards.
You need to prove ##x^{b+c-a}.y^{c+a-b}.z^{a+b-c}=1##, this is equivalent to showing ##\log x^{b+c-a}+\log y^{c+a-b}+\log z^{a+b-c}=0##, do you see why? If so, can you figure out the individual terms and show that their sum is zero?
Are you saying I have to prove [itex]b+c-a=0 \text{then } c+a-b=0 \text{ and } a+b-c=0[/itex]
No, I didn't mean that. Equate the equality to ##\lambda##. Can you find ##\log x^{b+c-a}## in terms of ##\lambda, a, b## and ##c##?
I am just 9th grade. I don't know anything about lambda other than it is a symbol for wavelength of light. I don't know the value of lambda. Can you explain clearly?
Wavelength? :-p
I meant ##\lambda## as some constant, you can even name it ##\alpha## if you wish to. What I meant was this:
$$\frac{\log x}{b-c}=\frac{\log y}{c-a}=\frac{\log z}{a-b}=\lambda$$
Can you make sense of this now? :smile:
I can't understand how to prove this. expressing ##\log x^{b+c-a}## in terms of ##\lambda, a, b## and ##c##, ##10^{\lambda}=x^{b+c-a}##.
Or I tried as I said in the first post of this thread.
Can you give a small hint if you have already solved it.
I don't see how you get that.
You have the following:
$$\frac{\log x}{b-c}=\lambda$$
Can you find ##\log x^{b+c-a}## from here? (Hint: Multiply both the sides by ##b+c-a##)
I get
[itex] <br /> \\\log x^{b+c-a}=\lambda\frac{b+c-a}{b-c}\\\\<br /> \\\log y^{c+a-b}=\lambda\frac{c+a-b}{c-a}\\\\<br /> \\\log z^{a+b-c}=\lambda\frac{a+b-c}{a-b}\\\\<br /> <br /> \\\log\left(x^{b+c-a}. y^{c+a-b}.z^{b+c-a}\right )=\lambda\frac{b+c-a}{b-c}+\lambda\frac{c+a-b}{c-a}+\lambda\frac{a+b-c}{a-b}<br /> [/itex]
Am I right till now?
Govind_Balaji said:
I get
[itex] <br /> \\\log x^{b+c-a}=\lambda\frac{b+c-a}{b-c}\\\\<br /> \\\log y^{c+a-b}=\lambda\frac{c+a-b}{c-a}\\\\<br /> \\\log z^{a+b-c}=\lambda\frac{a+b-c}{a-b}\\\\[/itex]
Are you sure that they should be in denominator?
Thank you, a small careless mistake.
The denominators should be in numerators.
I add them. I got 0.
Removing the log, I will get them equal to 0.
Thank you very much.
You are at 9th grade and you have studied logs?
I haven't still studied it. :cry:
I saw in your profile. You have done PhD and you have said that you are a professor.
Why are you kidding me?:-p
You can see my age(15 years). I am in Gr.10 :smile:
