Prove by the principle of induction
The discussion revolves around proving a mathematical expression using the principle of induction. Participants are exploring the validity of the expression for natural numbers, specifically starting with the base case and moving towards the induction step.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss checking the base case for n=1 and suggest substituting specific values to understand the expression better. There are attempts to relate the left-hand side and right-hand side of the equation through algebraic manipulation, with some participants expressing difficulty in establishing these relationships.
Several participants have provided insights and hints on how to approach the induction step, emphasizing the importance of simplifying both sides of the equation in equal ways. There is an ongoing exploration of how to apply the induction hypothesis effectively, with no explicit consensus reached yet.
Participants note the constraints of the homework context, indicating that they must show their work and reasoning as part of the assignment. Some express uncertainty about their understanding of the definitions and techniques involved in mathematical induction.
acrobaticelectron
I must find if this expression is true for any natural number
(n+n)=2^n(2n-1)
svg.image
(expression given to be proven)
check for p(1)... 2=2
svg.image
substitute (n+n) to
svg.image
And here is the problem, I just can't find a way to continue solving this problem
Maybe I am missing something. Try plugging in a number like n=5.
Maybe my understanding of the definition hasn't been correct, this is the exact definition of the exercise, thanks for your reply :)
Yes, that is very different. You have proven it is true for n=1. Now assume that it is true for a general n (including n=1) and see if you can use that to prove it is true for n+1.
So you want to prove that ##((n+1)+1)\cdot((n+1)+2)\cdot\cdot\cdot((n+1)+(n+1)) = 2^{n+1}\cdot 1\cdot 3\cdot 5\cdot\cdot\cdot(2(n+1)-1)##
Try to reorganize that equation into one that relates to the n-equation that is assumed to be true.
acrobaticelectron said:
Homework Statement:: I must find if this expression is true for any natural number
Relevant Equations:: (n+n)=2^n(2n-1)
svg.image
svg.image
substitute (n+n) to
svg.image
The formula in your revised version can be written as
P(n)\, : \,\dfrac{(2n)!}{n!}=2^n\cdot \prod_{k=1}^{2n-1}(2k-1)
You are correct with your induction base: ##\dfrac{(2\cdot 1)!}{1!}=2=2^1 \cdot \prod_{k=1}^1(2k-1).##
Next, you may assume that ##P(n)## is true (the induction hypothesis). You can also assume that ##P(m)## is true for all ##m\leq n## but I don't think this is necessary.
Finally (the induction step), we must somehow prove ##P(n+1).## The advantage of a proof by induction is, that we can use ##P(n)## as a proven statement. However, ##P(n+1)## is what we must show.
That is
P(n+1)\, : \,\dfrac{(2n+2)!}{(n+1)!}=(n+2)(n+3)\ldots (2n+2)\stackrel{!}{=}2^{n+1}\cdot 1\cdot 3 \ldots (2n+1)=2^{n+1}\cdot \prod_{k=1}^{2n+1}(2k-1)
You must prove ##(!)##. The way to do it, is to bring it into a form where you can apply ##P(n).##
Hint: Start on the right and write the product as ##c(n)\cdot 2^n\cdot \prod_{k=1}^{2n-1}(2k-1)## with some integer ##c(n)## and apply the induction hypothesis to it. Then bring it into the requested form on the left.
Thanks for your answer! I apreciate it , however my problem comes when I have to relate the equations, I am just not able to get the "right side" of the equation
That is
Thanks for the detailed answer, it really gives me some insight on the exercise. Right now I am a first year engineering student so I'm not really able to understand how you get the intuition to just convert one expression to one another, i would like to know what rule did you follow so I can learn it myself, thanks a lot!
As a homework problem, you will have to show us your work and we can make suggestions.
Try to rewrite each side into a form that uses the n-equation of that side.
Say ##P(n)\, : \,LHS(n)=RHS(n).## Then we must show ##P(n+1)\, : \,LHS(n+1)=RHS(n+1).##
So we start with
\begin{align*}
RHS(n+1)&=2^{n+1}\cdot 1\cdot 3\cdot 5 \cdot\ldots\cdot (2(n+1)-1)\\
&=2\cdot \left(2^{n}\cdot 1\cdot 3\cdot 5 \cdot\ldots\cdot (2n-1)\right)\cdot (2n+1)\\
&=2\cdot (2n+1)\cdot RHS(n)\\
&\stackrel{induction}{=}2\cdot (2n+1)\cdot LHS(n)\\
&\ldots \text{ etc. } \ldots\\
&=LHS(n+1)
\end{align*}
Hi, this is my work so far:
p(n)=(n+1)(n+2)(n+3)...(n+n)=2^n*1*3*5...(2n-1)
p(n+1)= (n+1+1)(n+2+1)(n+3+1)...(n+n)*(n+n+1)=2^(n+1)*1*3*5...(2n+1)
(n+1+1)(n+2+1)(n+3+1)...2^n*1*3*5...(2n-1)(n+n+1)=2^(n+1)*1*3*5...(2n+1)
this is were I get stuck, I'm just not able to solve this relationship
If you study post #9 and re-substitute my variables ##LHS(n)=\dfrac{(2n)!}{n!}## you will almost get the complete solution. It is important that you understand why these equations are there.
You don't want to "solve this relationship". You want to simplify both sides in "equal ways" to get two sides that are clearly equal.
Consider the right side. ##2^{n+1}=2\cdot 2^n## and ##1\cdot 3\cdot 5\cdot \cdot\cdot\cdot (2n-1)\cdot (2n+1) = [1\cdot 3\cdot 5\cdot \cdot\cdot\cdot (2n-1)] \cdot (2n+1)##
So ##RHS_{n+1} = 2\cdot RHS_n \cdot (2n+1) = 2\cdot (2n+1)\cdot RHS_n##.
Now do the same kind of thing with the left side. Then use the assumed fact that ##LHS_n = RHS_n## to divide out those factors from both sides. See where that goes.
Use that ##A\cdot LHS_n = B \cdot RHS_n \iff A=B##
There's no intuition required, only a solid mathematical technique. It's just the discipline to follow the inductive steps without getting your logic all mixed up.
In this case the answer drops out from no more than technique. No special algebraic tricks are required.
It may be worth describing the basic induction technique. Rather than RHS and LHS, I'll use ##a(n)## and ##b(n)##.
In general we want to prove that$$\forall n \ge 1: a(n) = b(n)$$The idea of induction is that we can prove this by showing that$$a(1)=b(1)$$and$$\forall n \ge 1: a(n) = b(n) \Rightarrow a(n+1) = b(n+1)$$The basic technique to do this has several steps:
1) Show that ##a(1) = b(1)## by direct computation.
2) Assume that for some fixed value of ##n## we have ##a(n) = b(n)##. We assume nothing about ##n## other than it is some number ##\ge 1##.
3) Write down the expression for ##a(n+1)##. This is done simply by plugging ##n+1## into the formula for ##a##.
4) Express ##a(n+1)## in terms of ##a(n)##. For example, it may be something of the form$$a(n+1) = ca(n) + d$$5) We know ##a(n) = b(n)## so we can express ##a(n+1)## in terms of ##b(n)##. E.g. $$a(n+1) = cb(n) + d$$.6) Show that this expression equals ##b(n+1)##. E.g. Show that$$cb(n) + d = b(n+1)$$Then we are done. Note that this last step may be simple or tricky. You may have to do a lot of work here.
That's the basic technique in cases like this and is perhaps a good introduction to thinking logically. In any case, steps 1-6 should make perfect sense before you tackle an inductive proof.
You have a error in your expression for proposition, ##P(n+1)##. It may be helpful to write it as follows.
##P(n+1)## states that
##((n\!+\!1)\!+\!1)((n\!+\!1)+2)((n\!+\!1)\!+\!3),,,((n\!+\!1)\!+\!n)((n\!+\!1)\!+n\!+\!1)
=2^{n+1}\!\cdot1\cdot3\cdot5\cdots(2(n\!+\!1)-\!1)##
Simplifying this (and listing some additional factors) gives for ##P(n+1)##:
##(n\!+\!2)(n\!+\!3)(n\!+\!4),,,(2n)(2n\!+\!1)(2n\!+\!2) =
2^{n+1}\!\cdot1\cdot3\cdot5\cdots(2n\!-\!1)(2n\!+\!1)##
Compare that with your expression for ##P(n)## to see how to get from ##P(n)## to ##P(n+1)##.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 24 ·
