Proving inf(x) = lim with Cauchy Sequence
  • Thread starter Thread starter *melinda*
The discussion centers on proving that for a set E bounded from below, the infimum x can be represented as the limit of a sequence x_n in E. The method proposed involves using the bisection technique, similar to that used for finding the supremum, to identify the infimum. By iteratively narrowing an interval [a,b] that contains E and checking midpoints, one can converge on the infimum. Once identified, a sequence can be constructed from elements of E that approach this limit.
  • Understanding of infimum and supremum in real analysis
  • Familiarity with Cauchy sequences
  • Knowledge of the bisection method for interval halving
  • Basic concepts of convergence in sequences
  • Study the properties of Cauchy sequences in detail
  • Learn about the bisection method and its applications in numerical analysis
  • Explore the concept of limits and convergence in real analysis
  • Investigate the relationship between infimum, supremum, and limits in mathematical analysis
Mathematics students, educators, and anyone interested in real analysis, particularly those studying sequences and convergence properties.
*melinda*
Question:
Suppose there is a set E\subset \Re is bounded from below.
Let x=inf(E)
Prove there exists a sequence x_1, x_2,... \in E, such that x=lim(x_n).
I am not sure but it seems like my x=lim(x_n) =liminf(x_n).
In class we constructed a Cauchy sequence by bisection to find sup. To do this proof I was thinking that I should do the same, but do it to find inf.
Does this seem like it will work?
Any suggestions would be greatly appreciated.
Thanks.
Yes, your approach is correct. You can use the same method of bisection to find the infimum of the set, and then construct a sequence that converges to it. The idea is to start with an interval [a,b] that covers E. Then, use the bisection method to find the infimum x. This means you will take the midpoint c of the interval [a,b] and check whether c is in E or not. If c is in E, then the infimum of E must be less than c, so you can then reduce the interval to [a,c]. If c is not in E, then the infimum of E must be greater than c, so you can reduce the interval to [c,b]. You can repeat this process until the interval is of size less than some arbitrary tolerance. Once you have found the infimum x, you can easily construct a sequence x_1, x_2, ... in E that converges to x by choosing elements of E that are close enough to x.
  • · Replies 44 ·
  • · Replies 25 ·
