Prove that spec of root 2 contains infinitely many powers of 2.
  • Thread starter Thread starter sachin123
    Root
The discussion centers on proving that the spec of root 2, defined as Spec√2 = {⌊k√2⌋ : k ≥ 0}, contains infinitely many powers of 2. Participants suggest using the expression k = floor(2^n * √2) to explore the binary representation of √2, which is irrational and lacks a repeating pattern. They emphasize that the floor function applied to k * √2 will truncate values, leading to the conclusion that the differences between powers of 2 and their floored counterparts can be shown to fall within specific intervals infinitely often. This approach is critical for establishing the desired proof.
  • Understanding of irrational numbers and their properties, specifically √2.
  • Familiarity with the floor function and its implications in mathematical proofs.
  • Knowledge of binary representation and its significance in number theory.
  • Basic concepts of sequences and limits in mathematics.
  • Research the properties of irrational numbers and their binary representations.
  • Study the implications of the floor function in number theory.
  • Explore sequences and their convergence, particularly in relation to powers of 2.
  • Investigate mathematical proofs involving inequalities and their applications in number theory.
Mathematicians, number theorists, and students interested in advanced mathematical proofs, particularly those focusing on irrational numbers and their properties.
sachin123
Spec of root 2 is that set of elements floor(k * (root 2)) ; k >= 0 .
I have no idea of how I can prove the statement in the question.
I need ideas on how to proceed.
Thank you
Thank you
What is meant by the "spec" of root 2? I have never seen that term.
RGV
Here, it means Spec√2= {⌊k√2⌋ : k≥0}
It's little tricky. Here's big hint. Pick k=floor(2^n*sqrt(2)). Think about what binary representation of sqrt(2) looks like. Play around with that for a while.
I've been thinking about it but I can't seem to move ahead.
sqrt(2) is irrational. It's binary representation has no pattern.
It would look like 1.0110101000001001111... and multiplying by 2^n would left-shift it n times.
Taking floor of this irrational number loses a portion of the number. And inside the Spec definition, we have floor (k * √2) and this floor would lose some number too.
Finally if √2 * √2 * 2 ^ n = 2 ^(n+1), this attempt leads to an interger smaller than that.
Where should I be heading?
Yeah, I'm actually running into the same problem. It's pretty easy to show 2^n*sqrt(2)-floor(2^n*sqrt(2)) is less than 1/2 an infinite number of times and I thought that would cover it, but I keep getting an inequality pointing the wrong way.
Ok, I think you can do it. You can either pick 2^n*sqrt(2)-floor(2^n*sqrt(2)) to be in (0,1/2) or (1/2,1) (both happen an infinite number of times). Note it would also work fine if you could show the choice of k=floor(2^n*sqrt(2))+1 works. Just draw some careful diagrams of where all the numbers lie relative to each other.
  • · Replies 20 ·
  • · Replies 22 ·
  • · Replies 27 ·
