KiwiKid
- 38
Prove that \lim_{x\rightarrow 0} \frac{1}{x} does not exist using the precise definitions of a limit.
Precise laws for infinite limits:
\lim_{x\rightarrow a} f(x) = \infty means that for every positive number M there is a positive number \delta such that if 0 < |x-a| < \delta then f(x)>M
and
\lim_{x\rightarrow a} f(x) = - \infty means that for every negative number N there is a positive number \delta such that if 0 < |x-a| < \delta then f(x) < N
There's also the precise laws for LHS- and RHS-limits:
\lim_{x\rightarrow a^-} f(x) = L if for every number \epsilon > 0 there is a number \delta > 0 such that if a - \delta < x < a then |f(x) - L| < \epsilon
and
\lim_{x\rightarrow a^+} f(x) = L if for every number \epsilon > 0 there is a number \delta > 0 such that if a < x < a + \delta then |f(x) - L| < \epsilon
And, of course:
If \lim_{x\rightarrow a^-} f(x) = L and \lim_{x\rightarrow a^+} f(x) = L, then \lim_{x\rightarrow a} f(x) = L. Otherwise, it is undefined.
Well, I think I've successfully proved it, but I'm not completely sure. My idea was to use the RHS- and LHS-limits to show that they differed, which would then show that the original limit does not exist. Here's my proof:
Proof of \lim_{x\rightarrow 0^+} \frac{1}{x} = \infty:
We have to define delta such that if 0 < x < \delta, then \frac{1}{x} > M
\frac{1}{x} > M \rightarrow x < \frac{1}{M}
Choose \delta = \frac{1}{M} \rightarrow 0 < x < \delta \rightarrow \frac{1}{x} > M
This shows that \lim_{x \rightarrow 0^+} \frac{1}{x} = \infty per the precise definition of a limit.
Proof of \lim_{x\rightarrow 0^-} \frac{1}{x} = - \infty:
We have to define delta such that if - \delta < x < 0, then \frac{1}{x} < N
\frac{1}{x} < N \rightarrow x > \frac{1}{N}
Choose \delta = \frac{-1}{N} \rightarrow - \delta < x < 0 \rightarrow \frac{-1}{N} < N
This shows that \lim_{x \rightarrow 0^-} \frac{1}{x} = - \infty per the precise definition of a limit.
Conclusion:
\lim_{x \rightarrow 0^+} \frac{1}{x} \neq \lim_{x \rightarrow 0^-} \frac{1}{x}
Therefore, the original limit does not exist.
...At least, that's the idea. I'm very unfamiliar with proofs, so did I do anything wrong? Would this be considered adequate proof?
EDIT: I just read that what my book calls the 'precise definition of a limit' is more officially known as the epsilon-delta limit definition.
