Prove that this mapping is a bijection
9 replies · 2K views · last reply
psie
Prove, using the definition, that ##\textbf{u}=\textbf{u}(\textbf{x})## is a bijection from the strip ##D=-\pi/2<x_1<\pi/2## in the ##x_1x_2##-plane onto the entire ##u_1,u_2##-plane.
##u_1 = \tan{(x_1)}+x_2##
##u_2 = x_2^3##
How would one tackle this using the definition? (i.e. for some function ff that f(x)=f(y)⟹x=yf(x)=f(y)⟹x=y implies an injection and y=f(x)y=f(x) for all yy in the codomain of ff for a surjection, provided such x∈Dx∈D exist.)
One can solve the system of equations for x1x1 and x2x2 and that shows that u=u(x)u=u(x) has an inverse x(u)x(u) and that u(x(u))=xu(x(u))=x. This would only show that uu is surjective, correct?
Yes,if you can find an inverse, you are done, no need to do anything else. But it must be a 2- sided inverse , you also need x(u(y))=y.
Right. How does one find that ##\textbf{u}(\textbf{x})## also is injective, i.e. that ##\textbf{x}(\textbf{u}(\textbf{x}))=\textbf{u}##?
Either find the left inverse or show ## f(x)=f(y) \rightarrow( x=y)## analytically or otherwise.
How would one go about finding the left inverse? To show ## f(x)=f(y) \rightarrow( x=y)##, do you mean to apply this to the separate functions within the vector ##\textbf{u}##? Then ##\tan{x_1}+x_2=\tan{y_1}+y_2##...
Well, you can use it with the original to test if it is 1-1 . If your left inverse exists , it shows the original is 1-1.
As @WWDG already said, you could find an inverse and be done.
Start by solving the equations
##u_1 = \tan(x_1)+x_2##
##u_2 = x_2^3##
for ##x_1## and ##x_2##.
I added parentheses in the tangent function -- in LaTeX, braces have a different function than parentheses. I'm assuming you meant ##\tan(x_1) + x_2## rather than ##\tan(x_1 + x_2)##.
##u_1 = \tan{x_1}+x_2##
##u_2 = x_2^3##
##x_1= \arctan{(u_1-u_2^{\frac{1}{3}})}##
##x_2= u_2^{\frac{1}{3}}##
This would imply ##\textbf{u}## is surjective.
But injectivity alone isn't sufficient. We also need the surjective part:
\mathbf{u}\, : \,D \stackrel{1:1}{\longrightarrow} \mathbb{R}^2
a.) ##\mathbf{u}(x)=\mathbf{u}(y) \Longrightarrow x=y##
b.) ##\mathbf{u}(D) \subseteq \mathbb{R}^2##
c.) ##\forall \,(v,w) \in \mathbb{R}^2 \,\exists \,(x,y)\in D\, : \,\mathbf{u}(x,y)=(v,w)##
Yes, i mentioned we need both right- and left- inverses. psie had provided a leftr inverse and i suggested he find a left inverse too.
