Prove that y(x) has finitely many positive zero
  • Thread starter Thread starter drawar
    Positive Zero
The discussion centers on proving that the nontrivial solution y(x) of the differential equation $$y'' + e^{-x}y = 0$$ has finitely many positive zeros. Participants reference Sturm's Comparison Theorem, which states that if q(x) > r(x) for positive functions, then y(x) must vanish at least once between any two successive zeros of z(x). The approach involves assuming that z'' + r(x)z = 0 has infinitely many zeros and deriving a contradiction by comparing it to the known solution z(x) = x sin(√C/x) for sufficiently large C.
  • Understanding of Sturm's Comparison Theorem
  • Familiarity with differential equations, specifically second-order linear equations
  • Knowledge of asymptotic behavior of functions as x approaches zero and infinity
  • Ability to manipulate inequalities involving functions
  • Study the implications of Sturm's Comparison Theorem in greater detail
  • Explore the behavior of solutions to second-order linear differential equations
  • Investigate the properties of the function sin(1/x) and its zeros
  • Learn about the asymptotic analysis of differential equations
Mathematicians, students studying differential equations, and anyone interested in the properties of solutions to linear differential equations.
drawar
Given $$y''+e^{-x}y=0. \qquad (*)$$ Let ##y(x)## be any nontrivial solution of ##(*)##, show that y has finitely many positive zeros.
Hint: Consider ##z''+\frac{C}{x^4}z=0## where ##C>0## is sufficiently large, which has a solution ##z(x)=x\sin \frac{\sqrt C}{x}##.
1. (Sturm's Comparison Theorem)
Let y(x) and z(x) be nontrivial solutions of
$$y'' + q(x)y = 0$$
and
$$z'' + r(x)z = 0, $$
where q(x) and r(x) are positive functions such that q(x) > r(x). Then y(x) vanishes at least once between any two successive zeros of z(x).
2. Moreover, if there exists a constant ##m>0## such that ##q(x) \geq m^2## for all x, then y(x) has infinitely many zeros.
My guess is ##C## must be big enough s.t ##\frac{C}{x^4}>e^{-x}##, so we can make use of the theorem. I also think that a proof by contradiction (i.e. suppose y has infinitely many positive zeros) may be useful, but don't know how to proceed further from here.
Could anyone shed some light on it please?
Your attempt looks good so far.
"Then y(x) vanishes at least once between any two successive zeros of z(x). "
As you use q(x) > r(x), q(r) will be your C/x^4 and r(x) will be e^(-x).
Therefore, your contradiction starts with "assume ##z'' + r(x)z = 0## has infinitely many zeroes [...]"
And then use the known solution for the other case to get a contradiction.That is a nice theorem.
Right, but noting that y and z in the problem statement have reversed roles from the y and z in the theorem statement.
Also, it doesn't quite get you there because sin(1/x) has infinitely many positive zeroes. You might need to split the range of x into (0, ε) and [ε, ∞).
Thank you for the help, but doesn't sin(1/x) have infinitely many zeros in [ε, ∞)?
I don't think so. Can you find any in (1/π, ∞)?
Oh that's enlightening, thank you!
  • · Replies 18 ·
