Prove the boundary of rationals is real
  • Thread starter Thread starter kekido
    Boundary
The discussion centers on proving that the boundary of the set of rational numbers, Q, is the set of all real numbers, R. Participants clarify the definitions of "boundary" and "boundary point," emphasizing that a boundary point must have neighborhoods containing both rational and irrational numbers. It is noted that the closure of Q minus its interior leads to the conclusion that the boundary is indeed R, supported by the density of rationals in the reals. The conversation highlights the importance of rigor in mathematical proofs and proper definitions. Ultimately, it is established that the boundary of Q is R, confirming the initial assertion.
kekido
Let Q be the set of all rational numbers
Prove bd(Q)=R
Let x be a real number, then since the interval |x-r| contains both rationals and irrationals for arbitrary small r, so R is the boundary of Q. Is that right?
Slow down a bit. What, exactly, is the definition of "boundary" and "boundary point". If you can answer that you should be able to answer your own question. (I might point out that, strictly speaking, |x-r| is not an interval, it is a number! You mean either the interval (x-r, x+r) or the set {y| |x-y|< r}.)
I would assume that
  • The boundary is the closure minus the interior
  • A point is in the closure if every epsilon-ball around it has non-empty intersection with the set
  • A point is in the interior if there is an epsilon-ball which fits entirely in the set
From these definitions it is quite straightforward to prove what the boundary of |R is, given (or proven) that the rationals are dense.
So kekido, your idea is right, but if you want to do it rigorously you should put a little more work into it (show that it satisfies the definitions yadayada andsoforth).
Ok, here "boundary" is the set of all boundary points, i.e., \partial(Q)=R
You're right, the interval should be like what you said. I was being sloppy here.
Since the boundary point is defined as for every neighbourhood of the point, it contains both points in S and S^c, so here every small interval of an arbitrary real number contains both rationals and irrationals, so \partial(Q)=R and also \partial(Q^c)=R
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 45 ·
