Prove the diagonals of a kite are perpendicular.
  • Thread starter Thread starter MklStar
    Perpendicular
The discussion focuses on proving that the diagonals of a non-square kite are perpendicular using vector mathematics. Participants emphasize the importance of employing the dot product, stating that if two vectors are perpendicular, their dot product equals zero. The kite is defined as a quadrilateral with two pairs of adjacent congruent sides, and the solution involves constructing vectors for the sides and diagonals, followed by calculating their dot product to demonstrate perpendicularity.
  • Understanding of vector mathematics
  • Familiarity with the dot product of vectors
  • Knowledge of kite geometry and properties
  • Ability to visualize geometric figures in a coordinate system
  • Study vector addition and subtraction techniques
  • Learn how to apply the dot product in geometric proofs
  • Explore the properties of kites and their diagonals in depth
  • Investigate coordinate geometry applications in vector analysis
Students studying geometry, mathematics educators, and anyone interested in vector applications in geometric proofs.
MklStar
As the title says, the question asks of us to: Prove that the diagonals of a non square kite are perpendicular using vectors.
if a is perpendicular to b then a . b =0
normal vector addition and subtraction
a kite made from points A B C D
..._a_A
....b| /\
...D...|/...\...B
...c|.\.../
C
AD = a + b
DC = a + c
b≠c
i know we have to use dot products but I am not sure how to implicate that into this...
Try drawing the sides as vectors and the diagonals as the vector sum of two sides.
A "kite" is a four sided figure having two pairs of congruent sides in which the congruent sides are adjacent. One "diagonal" separates the figure so that two congruent sides are one side of the diagonal, the other two congruent sides on the other. That is, you have two isosceles triangles. An altitude of an isosceles triangle, to the non-congurent side, is the perpendicular bisector of that side.
I get what you mean but how would I explain that with vectors?
I don't think I can just split the kite into 2 isosceles triangles and just say that from the middle of the base to the top, the angle is perpendicular.
As I said, draw the kite with the sides as vectors. Each diagonal is the vector sum of two sides. Take the dot product of those two diagonals (written as sums) and you should see how they work out to equal zero.
You can always assume a coordinate system so that one vertex, where two congruent sides join, is the origin and the diagonal at that point is the y-axis. Then the other vertex on that diagonal is (d, 0) for some number d and the other two points are (a, 0) and (-a, 0) for some number a. Construct the vectors along the diagonals and take the dot product.
  • · Replies 21 ·
