Prove using de moivre's theorem of I=cos^2n theta
  • Thread starter Thread starter indie452
    Theorem Theta
indie452
Use de Moivre's Theorem and the result that integral (with limits pi, 0) of cos[nx]dx = 0 for all non-zero integers of n. when n does equal 0 the answer is 1.
[this i proved in the first section of the qu using logic and limits(x->0).
so we need to prove that
integral[with limits pi, 0] [(cos(x))2n]dx = [pi / (2)2n] * [(2n)! / (n!)2]
de moivre -> (cos(nx) + i*sin(nx)) = (cos(x) + i*sin(x))n
eulers -> (cos(x) + i*sin(x)) = eix
okay I've tried not using de moivres and trying to find a pattern by doing the integral a few times, and I've also thought that using eulers formula might help, but i seriously just can't get started...i know that i need to use the real part of the formula but i don't know what to do first.this is a past exam paper by the way and my uni doesn't issue mark schemes, plus it being bank hols weekend no one will be there until wednesday
i appreciate any help or even just ideas on how to get started
thanks
cos(x) = (exp(ix) + exp(-ix))/2
Take both sides to the power 2n
Use the binomial theorem for the right-hand side
Integrate
well I've just done that between posting the qu and reading your reply and this is what I've done
cos(x)2n = 1 / 2^(2n) * (values of cos + (2n)! / ((n!)2))
the values of cos were found with setting n to various numbers and expanding
ie-
if n=2 :-values of cos were cos4x + 4cos2x
if n=3 :-values of cos were cos6x + 6cos4x + 15cos2x
but i don't know if i can do this without expanding and leaving n in there.
so with this equ integrated the cos becomes sin and then fall to 0 because integar numbers of pi is 0, and (2n)! / (n!)2 becomes (2n)! / ((n!)2) *x and the times this by the 1 / 2^(2n) gives the answer.
but once again i don't know whether i should know how to represent the 'values of cos' relating it to n [the main prob is the coefficients], cause i won't have this kind of time in the exam
Hi indie452! :smile:
(have a pi: π :wink:)
Use nealjking's :smile: two hints: cos(x) = (eix + e-ix)/2,
and (a + b)2n = ∑akb2n-k 2nCk
which coefficient(s) are the only ones with nonzero integral? :wink:
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
