Prove ||w + z|| <= ||w|| + ||z|| for complex vectors
s_j_sawyer
Let z, w be complex vectors of C^n.
(using the standard inner product for C^n)
(i.e. <w,z> = w*z', where * is the dot product and ' denotes the complex conjugate)
Well, I found that
||w + z||
= sqrt( w*w' + z*z' + z*w' + w*z')
= sqrt( w*w' + z*z' + <w,z> + <w,z>' )
and
||w|| + ||z||
= sqrt(w*w' + z*z')
So by showing that <w,z> + <w,z>' <= 0 then I guess that will finish the proof but I am unsure of how to do this.
Any help?
Well, I found that
||w + z||
and
||w|| + ||z||
= sqrt(w*w' + z*z')
The equation above isn't true. ||w|| = sqrt(w*w') and ||z|| = sqrt(z*z'), but the two square roots don't add to sqrt(w*w' + z*z'). This is like saying that the lengths of two sides of a right triangle add up to the length of the hypotenuse.
Any help?
Oooohhh deeaarr how embarrassing. Thank you for that insightful information. I should be able to get it now.
Sorry to double post but I didn't think simply editing would bump this up.
Alright so I played around with this some more but still could not get it to work.
I tried to prove this using the method of squaring both sides for the regular 'scalar triangle inequality' proof like so:
||w + z||^2 = (sqrt<w + z,w + z>)^2
= <w + z, w + z>
= <w,w> + <w,z> + <z,w> + <z,z>
= ||w||^2 + <w,z> + <w,z>' + ||z||^2
and so if I can show that
<w,z> + <w,z>' <= 2*||w||*||z||
then I would have
||w + z||^2 <= (||w|| + ||z||)^2
but I have been unable to do so. Any assistance would be greatly appreciated!
have you tried assuming a complex form, say w = aj + b and expanding the inner products?
[tex]\|w + z\|^2[/tex] is not equal to [tex]\langle w + z, w + z \rangle[/tex] unless you're in a real vector space. But since these are complex, then
[tex] \|w + z\|^2 = \langle w + z, \overline{w + z} \rangle[/tex]
Some hints:
If [tex]w[/tex] is a complex number (or vector, or whatever), then [tex]w = a + bi[/tex], where [tex]a[/tex] and [tex]b[/tex] are real numbers (or vectors), and
[tex] w + \overline{w} = a + bi + a - bi = 2a = 2\operatorname{Re}(w).[/tex]
Also, [tex]\operatorname{Re}(w) \le \|w\|[/tex]
These should hopefully get you on the right track.
