Proving a limit and the Order Limit Theorem
  • Thread starter Thread starter rbzima
    Limit Theorem
The discussion focuses on proving the convergence of the sequence (b_n) to b, given that (a_n) converges to 0 and the inequality |b_n - b| ≤ a_n holds. Participants clarify that since (a_n) approaches 0, for any ε > 0, there exists an N such that |a_n| < ε for n > N. This implies that |b_n - b| must also be less than ε, leading to the conclusion that (b_n) converges to b. However, there is a caution about needing additional restrictions on (a_n) or the inequality for the proof to be valid. The conversation emphasizes understanding the implications of convergence and the conditions necessary for the theorem to apply.
rbzima
If (a_n) \rightarrow 0 and \left|b_n - b\right| \leq a_n, then (b_n) \rightarrow b.
I'm a little bit stuck on proving this! Part (iii) of the Order Limit Theorem states:
Assume:lim a_n = a and lim b_n = b
If there exists c \in R for which c \leq b_n for all n \in N, then c \leq b. Similarly if a_n \leq c for all n \in N, then a \leq c.
I can then take this to a point where b_n = b, but somehow that doesn't seem right because \left|b_n - b\right|&lt;\epsilon, where \epsilon &gt; 0. Where am I going wrong here!
What happens if you choose n so large that |an| is less than epsilon? Why can you choose such an n?
That's exactly what I want. I want |an| to be less than epsilon because it implies convergence for any n, which means |an| is practically nothing because it approaches 0.
I'm not really sure what you are getting at here.
You know {an} converges to 0, what does that tell you?
b_n - b = 0
So, basically, b_n = b
But I'm wondering if that's really all that's necessary?
rbzima said:
b_n - b = 0
I don't understand how you get that from what I wrote.
Now IGNORE {bn} for a minute you know that {an} converges to zero, what does that mean?
We had a_n in the inequality, that's what I thought you were referring to.
Basically, the sequence approaches zero! Convergent series are bounded above and below, and a sequence converges when, for every positive integer \epsilon, there exists and N \in N such that whenever n \leq N, it follows that |an - a| < \epsilon.
I know the definition of convergence, in this case: |an| < \epsilon
Shall I list the properties of convergent sequences while I'm at it too! LOL!
If you are trying to prove just this part, than here you go:
since (a_n) \rightarrow 0 it means that for every e>o there exists some N(e)>0 such that whenever n>N we have Ia_nI<e, which actually is
-e<a_n<e
Now going back to \left|b_n - b\right| \leq a_n&lt;e which actually means that b_n converges to b.
what else are u looking for?
P.S. This is what d_leet also suggested, i guess!
-e<a_n<e
Two things. One please don't post entire solutions to questions such as this. And two, there actually needs to be an additional restriction to {an} or to the inequality of |b{sub]n[/sub]-b|<an in order for it to make sense; that restriction being either {an} is a sequence of positive terms or the inequality should be |bn-b|<|an|
  • · Replies 17 ·
