MHB Proving a trigonometric identity
The discussion revolves around proving a trigonometric identity involving cotangent and tangent functions. The original equation presented is not a valid identity, as it only holds true for specific values of x, namely x = π/2(2k±1) where k is an integer. Participants emphasize the importance of verifying whether a proposed identity is indeed valid before attempting to prove it, suggesting the use of tools like Wolfram Alpha for verification. The conversation highlights the common frustration of working with incorrect identities in trigonometry. Ultimately, the identity in question does not hold universally.
egillesp
Hi,
I need help proving the following trig identity:
$$\frac{\cot^2(x)-\cot(x)+1}{1-2\tan(x)+\tan^2(x)}=\frac{1+\cot^2(x)}{1+\tan^2(x)}$$
Me and my friend have spent several hours determined to figure this out, starting from the left hand side, the right hand side, and doing both together, but nothing seems to work.
For example, I tried to factor the left hand side, $$\frac{(\cot(x)-1)^2}{(\tan(x)-1)^2}$$, but it didn't get me anywhere.
Help would be greatly appreciated
Mathematics news on Phys.org
I tried fixing your $\LaTeX$, and the resulting identity is not true...can you clarify what the actual given identity should be?
The actual given identity is what I posted in the title and first thing in the thread
The equation given in your first post is not an identity. :D
okay, so what do you mean by a trig identity?
An identity is an equation that is true for all legitimate values of any variables in the equation.
The equation you posted is only true for:
$$x=\frac{\pi}{2}(2k\pm1)$$ where $$k\in\mathbb{Z}$$
okay thank you
egillesp said:
okay thank you
One of the first things I do when someone posts a trigonometric identity is to use W|A to check to see if it is in fact an identity, because often enough the given identity is in fact not true, and this saves a lot of time and hair pulling. :D
Here is where I checked:
>>click here<<
