Proving Cauchy Sequence with Triangle Inequality
  • Thread starter Thread starter SpringPhysics
    Cauchy Sequence
A sequence {xn} in ℝn is shown to be Cauchy if the sum of the distances || xn - xn+1 || is finite, indicating that the distances between terms decrease to zero. The triangle inequality is applied to relate the norms, leading to the conclusion that the sequence converges to a limit L. By the definition of a Cauchy sequence, for any ε > 0, there exist natural numbers N and M such that the distances from the limit are less than ε/2 for all n and m greater than these values. This confirms that the sequence satisfies the Cauchy condition. The discussion emphasizes the relationship between convergence and the Cauchy property in metric spaces.
SpringPhysics
If a sequence {xn} in ℝn satisfies that sum || xn - xn+1 || for n ≥ 1 is less than infinity, then show that the sequence is Cauchy.
The triangle inequality?
|| xm - xn || ≤ || Ʃ (xi+1 - xi) from i=n to m-1||
Using the triangle inequality and the given condition, I only get that the norm is less than infinity. I do not know how to transform this into an ε argument. Is there a property of finite sums of telescoping norms that would help?
every convergent sequence in a metric space is a cauchy sequence
so you could either take that as a theorem or prove it (it's pretty much a one liner)
so you just want to show that your series converges
I don't see how to show that the series converges if I am only given that the sum is finite. All I get from subtracting partial sums is that the norm of the difference is yet again finite...
If the sum of the distances between adjacent points converges then the distances must form a monotonically decreasing sequence such that \lim \limits_{n\to\infty}||x_n - x_{n+1}|| = 0 since distances are always non-negative.
What is the definition of a Cauchy sequence?
So by definition of a limit,
lim n→∞ xn = xn+1
which means that the sequence converges to some limit L.
From here:
- I can use either that any convergent sequence in ℝn must be Cauchy
- or that the above implies that there is some N, M (natural numbers) such that
|| xn - L || < ε/2 for all n > N
|| xm - L || < ε/2 for all m > M
so that the definition of a Cauchy sequence is satisfied for all n, m > max{N, M}.
Is that correct?
By the way...where do you find the code to format the limit? I couldn't find the latex for it.
lim n→∞ xn = xn+1
From here:
Is that correct?
A cauchy sequence is a sequence {p_n} such that for every \epsilon &gt; 0 there exists an integer N such that n,m&gt;N implies d(p_n,p_m) &lt; \epsilon
This means that the difference between each neighbouring members of the squence get smaller and smaller.
In the reals, suppose {p_n} \rightarrow P then there exists N such that n,m&gt;N
implies d(P,p_n) &lt; \frac{\epsilon}{2} and d(P,p_m) &lt; \frac{\epsilon}{2}
Therefore d(p_n,p_m) \leq d(P,p_n) + d(P,p_m) &lt; \epsilon
So every congergent sequence in R is a cauchy sequence
Can you see now what a cauchy sequence is?
So that's basically what I said in my previous post, right?
