Proving f(x) ≡ 0 with given conditions |f'(x)| ≤ M|f(x)| for 0 ≤ x ≤ L
  • Thread starter Thread starter hth
    Proof
The discussion revolves around proving that a function f(x) is identically zero under the conditions f(0)=0 and |f'(x)| ≤ M |f(x)| for 0 ≤ x ≤ L. The subject area includes differential equations and analysis.
  • Participants explore various approaches, including the Mean Value Theorem and the implications of the given conditions on the behavior of f(x). Some question the necessity of showing that f'(x) equals zero to conclude that f(x) is zero. Others discuss the implications of using supremum values and the potential for constructing sequences to demonstrate convergence to zero.
The discussion is ongoing with multiple lines of reasoning being explored. Some participants have offered hints and suggestions for approaches, while others express uncertainty about specific steps or intervals used in the proofs. There is no explicit consensus yet on the best method to prove the statement.
Participants note the importance of the condition M > 0 and discuss the implications of choosing specific intervals for analysis. There are concerns about the validity of certain assumptions and the correctness of specific inequalities derived during the discussion.
hth
Show that, if f(0)=0 and |f'(x)| ≤ M |f(x)| for 0 ≤ X ≤ L, show that on 0 ≤ X ≤ L that f(x) ≡ 0.
I'm having a hard getting this one started (as of right now, this seems a little over my head). At first, it seems like I need to find some polynomial where f(0)=0. Of course there are a lot of candidates for f(0) = 0.
Now, I know that |f(x)| = |∫0 to x of f'| ≤ M ∫0 to x of |f|, but can't seem to do anything else with it that progresses me further.
Any help is truly appreciated.
You'd be done if you could show that f'(x) = C, for any constant C right? for then f(0) would imply that f(x)=0.
Nope, he would need to show that f'(x)=0 in order to prove that f(x)=0. At the moment, I can't think of any way to do that however.
right, blah, that's what I meant.
Mean value theorem would be my guess. I might try to work though it.
Use the MVT multiple times. You should be able to construct a sequence that goes to 0, and "squeezes" f(x) to 0.
Yeah. So here is Rudin's Hint for doing this problem:
If you fix x_o < L, then using mean value you know that
f'(c)(x - a)=f'(x)- f(a), for some c < x_o. and x in 0<x<L If S is the supremum of f(x), and S' is the supremum of f'(x), you've shown
f(x)<S'(x - a) < SM(x - a), x<x_o
From there, I think you can go here:
f(x)<SM(x_o - a). Now, this can be done for any choice of x, so why not take the supremum of f(x) on the interval (0, x_o). Then you obtain S<SM(x_o - a).
I thought I had a proof but I tried to do it in my head and made a stupid mistake.
It is interesting to note that |f'(x)| ≤ M |f(x)| implies that |f'(x)| ≤ (M + N)|f(x)| with 0 ≤ N. If we let U = M + N for arbitrary N then we can work with a constant that's arbitrarily large instead of M. The trick would be to get it under something on the GT side.
updated my last message
Thx for the help guys. I'll work with your ideas, see what I can come up with and post it back here.
And here we go:
Proof.
Suppose M > 0. Then, take a point x_0 and fix x_0 < L.
Now, let S be the supremum of f and S' be the supremum of f' for a ≤ x ≤ x_0.
For any such x, f(x) - F(a) = = f'(c)(x-a) by Mean Value Theorem where x < c < a.
So, |f(x)| ≤ S'(x-a) ≤ S'(x_0 - a) ≤ SM (x_0 - a).
Hence, S = 0 if M(x_0 - a) < L. Therefore, f(x) = 0 on 0 ≤ X ≤ L.
End of proof.
Edit: Any comments on this will be appreciated.
Note that M has to be > 0 or else it kind of unravels itself.
I don't think this is obvious enough to just state. It works if (M*x_o-a) is less than one, but this requires a specific choice of x_o, and perhaps not the one which equals b.
Alright, here's a different approach I took:
Note: ck's are coefficients in the interval [0, 1/M].
Take any point, x, in the interval [0, 1/2M].
By MVT, f(x) = f(x) - f(0) = f'(ck)(x-0) = f'(ck)x for ck < x.
So, |f(x)| ≤ M |f'(ck)| |x| by the condition on f stated in the question.
Using the condition on f(ck) again,
|f(ck)| ≤ M |f(ck1)| |ck| then,
|f(x)|≤ M2 |f(ck1)| |x| |ck|
Repeatedly using MVT, you obtain
|f(x)| ≤ Mk |f(ck)| |x| |c1| |c2| etc.. where the c's are contained within [0, 1/2M].
So, in general,
|f(x)| ≤ (1/2)k |f(ck)|
Since f is continuous on [0, 1/2M] f is bounded and as k approaches infinity f(x) goes to zero.
Therefore, f(x) = 0.
Note: You'd use the same argument for [1/2M, 1/M] which is too much for me to type out.
Yeah, I like that one.
Alright, thank you.
Can I get someone else to double check that proof for me? There's a couple of things I'm not 100% confident about:
i.) That the intervals, [0,1/2M], [1/2M, 1/M] and [0, 1/M] are correct. Especially for 0 <= X <= L.
ii.) The part where I state |f(x)| ≤ (1/2)^k |f(c_k)|. Is that really OK?
10K
