Proving Isomorphism between Lie Algebras
45 replies · 6K views
micromass said:
Try a very trivial Lie bracket. What's the easiest Lie bracket around??
The one that's identically 0
on Phys.org
micromass said:
Indeed!
Note that this is exactly the Lie algebra of the diagonal 3x3 matrices!
So [itex]D_3(\mathbb{C})[/itex], the space of all 3x3 diagonal matrices with entries in [itex]\mathbb{C}[/itex] with lie bracket [itex][X,Y]= 0[/itex] for all [itex]X,Y\in D_3(\mathbb{C})[/itex] is not isomorphic to [itex]\mathfrak{g}[/itex] and [itex]\mathfrak{h}[/itex]?
When the question says 'show that your example meets the required conditions' does this mean I have to prove that it has dimension 3 and prove that it is not isomorphic? Would showing that a map from [itex]\mathfrak{f} \to \mathfrak{g}[/itex] and [itex]\mathfrak{f} \to \mathfrak{h}[/itex] defined by something aren't homomorphisms suffice?
Yes.
Won't work. There will certainly exist homormorphisms between those Lie algebra's. But there might not exist any isomorphism.
So, take [itex]\varphi[/itex] an isomorphism and try to deduce a contradiction.
micromass said:
Yes.
So can I just define mappings [tex]\varphi : \mathfrak{f} \to \mathfrak{g}[/tex] and [tex]\varphi : \mathfrak{f} \to \mathfrak{h}[/tex] in any way, assume they are isomorphisms and contradict this by showing the lie bracket isn't preseved?
But if I did this, I could do this with lie algebras which are isomorphic, assume I have a mapping that is an isomorphism (even though it isn't) and contradict the assumption. I need to show that there exist no isomorphisms at all between the lie algebras don't I?
micromass said:
Yes, but you won't be able to do this with Lie algebra's which are isomorphic.
So if I define [itex]\varphi : \mathfrak{f} \to \mathfrak{h}[/itex] by: [tex]\varphi \left( \begin{bmatrix} a & 0 & 0 \\ 0 & b & 0 \\ 0 & 0 & c \end{bmatrix} \right) = \begin{bmatrix} 0 & a & c \\ 0 & 0 & b \\ 0 & 0 & 0 \end{bmatrix}[/tex] how do I show the lie bracket [itex][X,Y]=0[/itex] for all [itex]X,Y \in \mathfrak{f}[/itex] isn't satisfied?
micromass said:
No, you can't take a specific [itex]\varphi[/itex].
What you do is take an arbitrary homomorphism [itex]\varphi[/itex] and assume that it is an isomorphism. You then show a contradiction.
You know nothing about [itex]\varphi[/itex] except that it's an isomorphism.
So if we assume [itex]\varphi[/itex] is an isomorphism.
Then [itex]\varphi ([x,y]) = [\varphi (x) , \varphi (y)][/itex] for all [itex]x,y \in \mathfrak{f}[/itex] since [itex]\varphi[/itex] is a homomorphism.
I'm not seeing how to use the fact that [itex]\varphi[/itex] is 1-1:
[itex]x=y \Rightarrow \varphi (x) = \varphi (y)[/itex]
micromass said:
Try to calculate
[tex]\varphi [E,F],~\varphi [F,G],~\varphi [E,G][/tex]
in several ways. See if you can get a contradiction.
Are we talking about the same [itex]E,F,G \in\mathfrak{g}[/itex] as before?
From the fact that [itex]\varphi[/itex] is a homomorphism, [itex]\varphi ([E,F]) = [\varphi (E),\varphi (F)][/itex] etc.
I thought I had to do something with diagonal matrices in [itex]\mathfrak{f}[/itex] and show that the lie bracket [x,y]=0 can't be satisfied?
micromass said:
Yes.
That works as well.
How am I supposed to calculate [itex]\varphi ([E,F])[/itex] etc. at all when I don't know what [itex]\varphi[/itex] is?
Also since [itex]\mathfrak{g}\cong\mathfrak{h}[/itex], if we show [itex]\mathfrak{f}\ncong\mathfrak{g}[/itex] then does that automatically imply that [itex]\mathfrak{f}\ncong\mathfrak{h}[/itex] ?
The question on giving an example and showing that the example meets the required conditions is worth very few marks in this exam paper compared to the question on showing [itex]\mathfrak{g}\cong\mathfrak{h}[/itex].
Isn't there some obvious property that [itex]D_3(\mathbb{C})[/itex] endowed with lie bracket [itex][X,Y]=0[/itex] has that means it cannot be isomorphic to [itex]\mathfrak{g}[/itex] or [itex]\mathfrak{h}[/itex] ?
Can't I just say that since there is a non-trivial Lie bracket in both [itex]\mathfrak{g}[/itex] and [itex]\mathfrak{h}[/itex], they cannot be isomorphic to [itex]\mathfrak{f}[/itex] since all Lie brackets are trivial in [itex]\mathfrak{f}[/itex] and isomorphisms preserve Lie brackets?
Also for showing that [itex]\varphi (aE + bF + cG) = \begin{bmatrix} 0 & a & c \\ 0 & 0 & b \\ 0 & 0 & 0 \end{bmatrix}[/itex] is 1-1 is this proof OK:
Letting [itex]x = aE+bF+cG \in \mathfrak{g}[/itex] and [itex]y = a'E+b'F+c'G \in \mathfrak{g}[/itex],
[itex]\varphi (x) = \varphi (y) \Rightarrow \begin{bmatrix} 0 & a & c \\ 0 & 0 & b \\ 0 & 0 & 0 \end{bmatrix} = \begin{bmatrix} 0 & a' & c' \\ 0 & 0 & b' \\ 0 & 0 & 0 \end{bmatrix}[/itex]
[itex]\Rightarrow aE +bF+cG = a'E + b'F + c'G[/itex] i.e. [itex]x=y[/itex]
How would I show [itex]\varphi[/itex] is onto?
micromass said:
Is this an exam??
Just a past paper but we don't get the solutions you see
