Proving Magnitude & Phase of H(e^jw)
  • Thread starter Thread starter JeeebeZ
    Magnitude Phase
The discussion revolves around proving the magnitude and phase of the function H(e^jw), defined as H(e^jw) = (1-1.25e^(-jw))/(1-0.8e^(-jw)). Participants are tasked with demonstrating that |H(e^jw)|^2 equals G^2, identifying G, and finding both the magnitude and phase of the function.
  • Participants explore different forms of H(e^jw) and question how to approach finding its magnitude. There are inquiries about the definition of the magnitude of a complex number and discussions on identifying real and imaginary parts. Some participants suggest using the relationship between a complex number and its conjugate to derive |H(e^jw)|^2.
There is an ongoing exploration of the problem, with some participants providing insights into the relationships between the components of H(e^jw). A participant has derived an expression for |H(e^jw)|^2 and identified a specific value for G, while others reflect on the implications of this result and the nature of the phasors involved.
Participants are working within the constraints of homework guidelines, which may limit the extent of direct assistance provided. There is a focus on understanding the underlying concepts rather than simply arriving at a solution.
JeeebeZ
Prove |H(e^jw)|^2 = G^2, and what is G
Find Magnitude & Phase
H(e^jw) = (e^(jw)-1.25)/(e^(jw)-0.8)
H(e^jw) = 1 - (0.45e^(-jw))/(1-0.8e^(-jw))
H(e^jw) = 1 - 0.45/(e^(jw)-0.8)
I don't know how to approch this question. I can rewrite H(e^jw) in 4 different formats, but none of which make me understand how to attempt to get the magnitude in the first place.
this would be:$$H(e^{j\omega})=\frac{1-(1.25)e^{-j\omega}}{1-(0.8)e^{-j\omega}}$$
What is the definition of the magnitude of a complex exponential/number?
$$Magnitude = \sqrt{Re(z)^2 + Im(z)^2}$$
Great - so all you need to do is identify the real and imaginary parts of ##H(e^{j\omega})## ... how do you do that?
Hint: the exponential describes a phasor.
Because |Z|^2 = z * zbar
we have
$$|H(e^{j\omega})|^2=(\frac{1-(1.25)e^{-j\omega}}{1-(0.8)e^{-j\omega}})(\frac{1-(1.25)e^{j\omega}}{1-(0.8)e^{j\omega}})$$
substituting
$$x=e^{j\omega}$$
$$|H(e^{j\omega})|^2=(\frac{1-(1.25)x^-1}{1-(0.8)x^-1})(\frac{1-(1.25)x}{1-(0.8)x})$$
$$|H(e^{j\omega})|^2=(\frac{1-(1.25)x^-1-(1.25)x + 1.25^2}{1-(0.8)x^-1-(0.8)x+0.8^2})(\frac{x}{x})$$
$$|H(e^{j\omega})|^2=\frac{x-(1.25)-(1.25)x^2 + 1.25^2x}{x-(0.8)-(0.8)x^2+0.8^2x}$$
$$|H(e^{j\omega})|^2=\frac{-1.25}{-0.80}\frac{x^2 + 2.05x - 1}{x^2 + 2.05x -1}$$
$$|H(e^{j\omega})|^2=\frac{-1.25}{-0.80} = 1.5625$$
$$|H(e^{j\omega})|= G = 1.25 = magnitude$$
I got the Phase by computing the two angles, one on top with arctan (Im/Re), and the one on bottom, then phase total = top - bottom.
See - you didn't need me :)
Hmmm ... I notice that 1.25 is the magnitude of one of the phasors in the combination which is a little startling. The second to last line says that the magnitude is the square-root of the ratio of the magnitudes of the phasors. You could explore to see if this is a general result or just a judicious choice of amplitudes.
Some latex notes (just sayin'):
you can use \left ( <some stuff> \right ) to fit brackets around the bigger stuff so
\left ( \frac{q}{p-1} \right ) gives you $$\left ( \frac{q}{p-1} \right )$$
the complex conjugate is usually better represented by a star notation as in ##z^*## or ##z^\star## - the bar gets tricky to typeset after a bit and you risk confusing ##z_{ave}=\bar{z}## ...
I've never used latex before I just quoted yours and edited it as needed but I'll keep it in mind for the future. Thx
You did well at that too :) Most people just go "meh".
Them I don't usually bother to give pointers ;)
  • · Replies 108 ·
36K
