Proving Polynomial Properties: Existence of nxn Matrix in Field k
  • Context: Graduate
  • Thread starter Thread starter DeadWolfe
    Stupid
For any degree n polynomial p(x) with coefficients in a field k, there exists an nxn matrix with entries in k that has p as its characteristic polynomial. A diagonal matrix with entries λ_1, λ_2, ..., λ_n has the characteristic polynomial formed by the product (x - λ_1)(x - λ_2)...(x - λ_n). The discussion highlights that while constructing matrices for polynomials with complex roots can be challenging, particularly when the roots lie outside the field, companion matrices provide a systematic approach to prove this for general cases, especially when k is algebraically closed.
  • Understanding of characteristic polynomials
  • Familiarity with diagonal matrices
  • Knowledge of algebraically closed fields
  • Concept of companion matrices
  • Research the properties of companion matrices in linear algebra
  • Study the implications of algebraically closed fields in polynomial theory
  • Explore the construction of matrices for polynomials with complex roots
  • Learn about the relationship between matrix similarity and characteristic polynomials
Mathematicians, students of linear algebra, and anyone interested in polynomial theory and matrix representation in fields.
DeadWolfe
How might one prove that for any degree n polynomial p(x) with coefficients lying in a field k, there exists any nxn matrix with entries in k with characteristic polynomial p?
If you have a diagonal matrix with entries \lambda_1, \lambda_2, \cdots, \lambda_n then what is its characteristic polynomial?
[addition]It's not as easy as I thought. For example, the polynomial x^2 + 1 has real coefficients, two complex roots, and there is a matrix with real entries - namely [[0 1] [-1 0]] - of which it is the characteristic polynomial. So it's not as easy as just taking diag(first root, second root, ...) in the case where the roots can be outside the field (this has a name, I think it is "algebraically closed"?). Of course changing the basis does not change the characteristic polynomial and in my example that is the trick to get a real matrix but you'd have to prove that it is generally possible). But the proof is easy for algebraically closed fields (if that is indeed the name).
Yes, but of course I was interested in the general case (and particularly when k=reals)
Look into companion matrices.
  • · Replies 24 ·
  • · Replies 0 ·
