Proving r² θ-dot is a first integral in central force motion
  • Thread starter Thread starter raopeng
    Integral
17 replies · 3K views · last reply
raopeng
Prove that [itex]r^2 \dot{θ}[/itex] is a first integral in any central field.
for a first integral it suffices that [itex]L_v f = 0[/itex]
central field:[itex]\ddot{\vec{r}}=f(r)\vec{r}[/itex] where f(r) is an arbitrary function of r.
Physically it seems quite obvious. θ is implicit in the Newtonian equation, thus the Lagrangian is invariant under the transformation group of rotation, hence the conservation law.
But for a more mathematical solution, directional direvative [itex]L_v[/itex] of [itex]r^2 \dot{θ}[/itex] only gives [itex]2r\dot{r}\dot{θ}, r^2\ddot{θ}[/itex] which alone does not guarantee its value to be zero. And how should I build connections between the given first integral and the Newtonian equation? Thanks guys.
Vector-multiply the Newtonian equation with the r vector.
Thanks for the reply but I am sorry that I cannot figure out your hint and in the end I get around using another method: since the acceleration is only radial, the angular component of the acceleration must be zero. Making use of this expression and substitute in the time derivative of the given first integral which then equals to zero. Although it sounds too "physical" for a mathematical book..
You have ## \displaystyle \ddot{\vec{r}} = f(r)\vec{r} ##. Multiplying, we get ## \displaystyle \vec{r} \times \ddot{\vec{r}} = \vec{r} \times f(r)\vec{r} = f(r) \vec{r} \times \vec{r}##. What can be said about the right hand side?
I get it would be zero, but this seems to be unrelated to the first integral or its derivative. I think that is used to prove the conservation of [itex][\vec{r}, \vec{\dot{r}}][/itex] which is not totally the same with this one...sorry if I am being slow..
So we get ## \displaystyle \vec{r} \times \ddot{\vec{r}} = 0 ##. Can you see that on the left hand side we have a time-derivative of ## \displaystyle \vec{r} \times \dot{\vec{r}} ##?
What does that imply about the plane of motion? Can you really talk about a "plane of motion'?
eh yes I know that, but like I said above the conservation of [itex][\vec{r}, \vec{\dot{r}}][/itex] as a vector quantity is not totally equivalent to the conservation of [itex]r^2 \dot{w}[/itex] as a scalar.
It means the moving body always remain in that plane made up by speed and coordinate since the vector is constant?
Exactly. Since we have ## \displaystyle \vec{r} \times \dot{\vec{r}} = \vec{l} ##, the latter being a constant of motion (angular momentum), ## \vec{r} ## must be at all times be perpendicular to a fixed direction, which means it lies in a plane. By the same token, the velocity also lies in the same plane.
Now, because we have a plane of motion, the problem is reduced to 2D, and you can introduce some (arbitrary) vector in the plane, and then you will have angle ## \theta ##, which is the the angle between that vector and ## \vec{r} ##, and which is always measured in that plane.
## \dot{\theta} ## is angular velocity.
Can you represent ## \dot{\vec{r}} ## as a sum of radial (parallel to ## \vec{r} ##) and tangential velocities?
Do you mean to obtain both the tangential and radial velocity and differentiate it with regards to time to obtain the tangential acceleration? It is my original method: because the tangential acceleration is clearly 0 by the Newtonian equation, and substitute that into the derivative of [itex]r^2\dot{θ}[/itex] to realize that the latter is zero which proves its first integral property.
No, I do not mean this. ## \displaystyle \dot{\vec{r}} = \vec{\rho} + \vec{\tau} ##, the sum of radial and tangential velocities, respectively. Now substitute this into the ## \displaystyle \vec{r} \times \dot{\vec{r}} ##.
[itex][\vec{r}, \vec{\dot{r}}]=[\vec{r}, \dot{r} \vec{e_r} + r\dot{θ}\vec{e_θ}][/itex] where [itex]\vec{e_r}, \vec{e_θ}[/itex] being the tangential and radial direction vector. differentiate it with t gives [itex]r^2\dot{θ}[e_r, e_θ][/itex] thus proves its conservation.
But why do you need to differentiate this? You already have ## \displaystyle \vec{r} \times \dot{\vec{r}} = r^2\dot{\theta}\vec{e}_n = \vec{l} ##.
Ehh sorry don't know what is in my head when I typed that.. And thanks for your time on this.
You are welcome. I hope you will memorize that the integral (a.k.a Kepler's second law) and planar motion are a direct consequence conservation of angular momentum in a central field.
Yes and angular momentum differs from it as a geometric quantity by its mechanical parameter m. Well I was initially working on a "purely" mathematical proof because it shows up in an ODE book on first integrals.. it gets quite confusing when known physical concepts come into relation to pure mathematics
There is no "purely" mathematical proof because the question itself is based on certain physical assumptions. Namely, that the motion can be described by just two variables, a distance and an angle. And this follows only when you prove that angular momentum is conserved. Well, one could, of course, just ignore that that quantity has a "physical" name, but that is as "mathematical" as it gets.
