MHB Proving Shortest Distance Between 3 Points on a Circle
  • Thread starter Thread starter roni1
    Circle Points
The discussion revolves around proving that the shortest distance between any two points on the perimeter of a circle is less than the distance that includes a third point. The original poster seeks clarification on whether this pertains to distances along the circumference or straight segments connecting the points. Participants suggest that a diagram could help clarify the question, but confusion remains about the exact nature of the inquiry. One response indicates that the distance between the points could range from 0 to the diameter of the circle. The conversation highlights the need for clearer definitions to address the mathematical proof effectively.
roni1
I have 3 point on a perimeter of circle.
How I prove/show between every the two point of them there is always short way that the way between the other points?
Mathematics news on Phys.org
Re: question
Are you talking about the distance along the circumference of the circle?
Re: question
I mean to segments between the 3 points.
Re: question
Can you provide a diagram illustrating what you're trying to do?
Re: question
The answer:
The distance be between 0 to D.
D = diameter.
Am I right?
Re: question
roni said:
The answer:
D = diameter.
Am I right?
As it seems that we don't know what the question is asking I don't think anyone can tell you if that's right or not.
-Dan
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
