Proving that \sqrt{p} is irrational
  • Thread starter Thread starter Mandelbroth
    Irrational
The discussion revolves around a proposed proof that \(\sqrt{p}\) is irrational for a prime number \(p\). The argument begins with assuming \(\sqrt{p} = \frac{m}{n}\) for coprime integers \(m\) and \(n\), leading to the conclusion that \(n^2\) must equal 1 for \(\frac{m^2}{n^2}\) to remain an integer. This implies \(m^2 = p\), suggesting that \(p\) is a perfect square, which contradicts the nature of prime numbers. Participants agree that the proof is valid and applicable to any positive integer, emphasizing that the square root cannot be a proper rational number. The conclusion is that the proof effectively demonstrates the irrationality of \(\sqrt{p}\).
Mandelbroth
I'm aware of the standard proof.
What I'm wondering is why we can't just do the following. Given, I haven't slept well and I'm currently out of caffeine, so this one might be trivial for you guys.
Suppose, by way of contradiction, that ##\sqrt{p}=\frac{m}{n}##, for ##m,n\in\mathbb{Z}## coprime. Then, ##p=\frac{m^2}{n^2}##. Because ##p## is an integer, ##\frac{m^2}{n^2}## must be as well. However, because ##m## and ##n## are coprime, so are ##m^2## and ##n^2##. Thus, ##n^2=1## is necessary for ##\frac{m^2}{n^2}## to be an integer. But that means ##m^2=p##, and ##p## is prime. Thus, a contradiction is met and we see that ##\sqrt{p}## is irrational.
Is this valid? I'll probably figure out my mistake (if I made one) by the time I get back with adequate caffeination, but until then, I'd like to make sure I figure it out.
Thank you.
Edit: Gee, I guess it might be important to mention that ##p## is prime. :facepalm:
Mathematics news on Phys.org
In my opinion, it's valid.
Likes 1 person
It looks OK to me.
Likes 1 person
Completely valid. The last step basically assumes that a prime cannot be a perfect square, which is true and fairly obvious. But if you really want to make the proof completely obvious, you can state: ##m^2 = p##. Hence ##m|p## (m divides p), which is a contradiction.
Likes 1 person
Actually, it doesn't matter that p is prime. It's valid for any +ve integer: the square root is either an integer or irrational; it cannot be a proper rational.
Thank you, all.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
