Proving that \sqrt{p} is irrational
  • Level: Undergrad
  • Thread starter Mandelbroth
    Irrational
Mandelbroth
I'm aware of the standard proof.
What I'm wondering is why we can't just do the following. Given, I haven't slept well and I'm currently out of caffeine, so this one might be trivial for you guys.
Suppose, by way of contradiction, that ##\sqrt{p}=\frac{m}{n}##, for ##m,n\in\mathbb{Z}## coprime. Then, ##p=\frac{m^2}{n^2}##. Because ##p## is an integer, ##\frac{m^2}{n^2}## must be as well. However, because ##m## and ##n## are coprime, so are ##m^2## and ##n^2##. Thus, ##n^2=1## is necessary for ##\frac{m^2}{n^2}## to be an integer. But that means ##m^2=p##, and ##p## is prime. Thus, a contradiction is met and we see that ##\sqrt{p}## is irrational.
Is this valid? I'll probably figure out my mistake (if I made one) by the time I get back with adequate caffeination, but until then, I'd like to make sure I figure it out.
Thank you.
Edit: Gee, I guess it might be important to mention that ##p## is prime. :facepalm:
In my opinion, it's valid.
Completely valid. The last step basically assumes that a prime cannot be a perfect square, which is true and fairly obvious. But if you really want to make the proof completely obvious, you can state: ##m^2 = p##. Hence ##m|p## (m divides p), which is a contradiction.
Actually, it doesn't matter that p is prime. It's valid for any +ve integer: the square root is either an integer or irrational; it cannot be a proper rational.
