Proving the Exponent Laws in Group Theory
14 replies · 2K views
Bashyboy
Let ##x \in G## and ##a,b \in \mathbb{Z}^+## Prove that ##x^{a+b} = x^a x^b##.
If I am not mistaken, we would have to do multiple induction on ##a## and ##b## for the statement/proposition ##P(a,b) : x^{a+b} = x^a x^b##. First we would have to show that ##P(a,1)## and ##P(1,b)## are true (base cases). But due to symmetry, it suffices to prove ##P(a,1): x^{a+1} = x^a x##. This is where I had trouble; I thought I would have to do induction on the statement on the statement ##P(a,1)##.
After trying many things, I decided to consult this https://crazyproject.wordpress.com/2010/01/04/laws-of-exponents-in-a-group/ This person appears to be doing the same as myself. But I found it unsettling that no justification was given for ##x^{a+1} = x^a x## (the base case); what is written is this: "For the base case, note that
for all
The only way I could think of justifying it is as follows:
##x^{a+1} = \underbrace{x \cdot x \cdot ... \cdot x}_{(a+1)~terms}##
##= \underbrace{(x \cdot x \cdot ... \cdot x)}_{a ~terms} x## (associative property)
##= x^a x## (by definition of what ##x^a## means)But if we can do that, then why not do similar splitting with ##a^{a+b}## , thereby avoiding all induction?
Dummit and Foote doesn't specify, but I imagine they are regarding it as a group.
I don't see the symmetry off hand, unless you have an "extended" associative property. (I suppose that's always implied.)
At any rate, it looks like induction on b is all that's required.
for all
It looks like they just sketched the proof, leaving the reader to fill in some things they thought to be obvious, or at least fairly straight forward.
That shouldn't even require associativeity if normal order of operations is left to right.
##x^{a+1}= \underbrace{\left(\dots\left(\left(\left(x \cdot x \right)\cdot x\right)\cdot x\right) ... \cdot x\right)}_{a ~\text{factors}} \cdot x##​
(Surely you mean ##\ x^{a+b}\ ## in the above line.)
Induction isn't that difficult for this.
Assume that ##\ x^{a+n} = x^a x^n\ ## for some n ≥ 1. From that show that ##\ x^{a+(n+1)} = x^a x^{n+1}\ ## follows.
xa+1=(…(((x⋅x)⋅x)⋅x)...⋅x)a factors⋅xxa+1=(…(((x⋅x)⋅x)⋅x)...⋅x)⏟a factors⋅xx^{a+1}= \underbrace{\left(\dots\left(\left(\left(x \cdot x \right)\cdot x\right)\cdot x\right) ... \cdot x\right)}_{a ~\text{factors}} \cdot x
So, are you saying that this is a valid way of establishing ##x^{a+1} = x^a x##? If so, then why can't I do the following:
##x^{a+b} = \underbrace{x \cdot x \cdot ... \cdot x}_{(a+b)-terms}##
##= \underbrace{x \cdot x \cdot ... \cdot x}_{a~terms} \cdot \underbrace{x \cdot x \cdot ... \cdot x}_{b~terms}###
##=x^a x^b##,
thereby avoiding induction.
##=x^a x^b##,
I'm not saying you can or you can't do that.
It's partly a matter of what you have previously proved and what you have not proved.
Doing the inductive proof doesn't require you to assume much of anything.
Do you understand inductive proof ?
I am still wondering about the justification of the base case ##x^{a+1} = x^a x##.
I probably should have restated that it's not the associative law. It's basically just the definition of what is meant by ##\ x^n\,,\ ## perhaps along with the standard order of operations being left to right.
And we agree that the definition of ##x^n## is ##x^n = \underbrace{x \cdot x \cdot ... \cdot x}_{n-terms}##? If so, then for ##n=a+b##
##x^{a+b} = \underbrace{x \cdot x \cdot x ... \cdot x}_{(a+b)-terms}##
##= \underbrace{x \cdot x \cdot ... \cdot x}_{a} \cdot \underbrace{x \cdot x \cdot ... \cdot x}_{b}##.
##=x^a x^b##.
which is my problem. There is some subtle logic that is preventing me from seeing the need of any induction, as well as how we justify ##x^{a+1} = x^a x##.
Yes, we do have the generalized associative property; this is proved in the chapter before this problem.
Where did you find this? In my Dummit and Foote book, the only thing that holds by definition is ##a^0 = e##.
I found a copy of your book online, and it appears it is defined by that phrase. In that case, I think your non-inductive proof is fine.
On the other hand, if ##x^n## is defined as ##x^{n-1}x## with ##x^0=e##, then I can see where you'd want to prove the law by induction.
