Proving the Oplus Symbol: A, B, C, D Sets - Solving the SETS Problem
  • Thread starter Thread starter majeedh
    Sets
The discussion revolves around proving a set equality involving the symmetric difference, represented by the oplus symbol, for four sets A, B, C, and D. The specific equation in question is whether (A Φ B) Φ (C Φ D) equals (A Φ C) Φ (B Φ D).
  • Participants explore the meaning of the oplus symbol and its relation to symmetric difference. There are attempts to clarify definitions and the nature of the operation involved. Some participants express uncertainty about how to begin the proof and question which proof techniques might be appropriate.
There is a mix of attempts to understand the problem and suggestions for approaches, such as drawing diagrams or writing out definitions. Some participants are still feeling lost, while others are trying to clarify the definitions and relationships between the sets involved.
Participants mention feeling confused about how to start the proof and the best methods to use, indicating a lack of clarity on the definitions and properties of the symmetric difference.
majeedh
this is one problem which i don't know how to start..im not sure which proof i should use to solve this problem
the problem is:
If A,B,C,and D are sets, does it follow
(A Φ B) Φ (C Φ D) = (A Φ C) Φ (B Φ D)
the symbol that is separting the characters is called the oplus symbol, that's the closet symbol i could find
the oplus symbol is a circle with one line going across it and one line going down
no it doesnt
the symbol I am trying to illustrate there is the oplus which can be viewed at this link
http://www.artofproblemsolving.com/LaTeX/AoPS_L_GuideSym.php
Does that mean the XOR operation, ie, A \oplus B = (A-B) \cup (B-A), also known as the symmetric difference? What have you tried?
yes that is the symbol which I am referring to...symmetric difference
i don't know where to start..i have no clue on what to do?
Start by trying to see if it's true. You can draw a picture, something like 4 overlapping circles, and see if you can find the regions corresponding to each side of that equation.
i have tried to draw circles before...but i just keep getting lost..i don't know how to proof this and which would be the best proof to use in such a case..im totally lost on how to start the problem
Ok, then just write out the definitions. Get everything in terms of unions, intersections and complements, which should be easier to work with.
im going to see what i can come up with..but iam clueless in what to do...
You want to prove that two sets, the set on the left side and the set on the right side, are equal. Typically you do that by proving that anything in one of the sets is also in the other.
Suppose x is in (A\oplus B)\oplus (C\oplus D). What must be true about it? From the definition, if a point, p, is in A\oplus B is it in A or B? exactly what is true about p from the definitions? Once you know exactly where, relative to A, B, C, D, p must be in order to be in the left set, use that information to show that it must be in the right set.
Now reverse and do it the other way.
