Proving the Sequence of Real Numbers is Not Cauchy
The sequence defined by x_{n + 1} = x_n + \frac{1}{x_n^2}, starting with x_1 = 1, is shown to be not Cauchy by examining its behavior as n approaches infinity. It is established that if the sequence were Cauchy, it would converge to a limit L, leading to the conclusion that \lim_{n \to \infty} \frac{1}{x_n^2} must equal 0. However, this implies that \lim_{n \to \infty} x_n^2 equals infinity, which contradicts the existence of a finite limit L. Therefore, the sequence cannot be Cauchy, as it does not converge. The discussion highlights the importance of understanding the relationship between Cauchy sequences and convergence.
tylerc1991
Show that the sequence of real numbers defined by x_{n + 1} = x_n + \frac{1}{x_n^2}, \, x_1 = 1 is not a Cauchy sequence.
A sequence \{ p_n \} is Cauchy if and only if, for all \varepsilon > 0, there exists an N > 0 such that d(p_n, p_m) < \varepsilon for all m, n > N.
We can assume that d is the usual metric on \mathbb{R}. I don't even see where to begin. I see that the sequence is monotonically increasing, so that
1 = \frac{1}{x_1} > \frac{1}{x_2} > \frac{1}{x_3} > \dotsb.
So
1 = \frac{1}{x_1^2} > \frac{1}{x_2^2} > \frac{1}{x_3^2} > \dotsb.
To me it looks like the sequence is in fact Cauchy. Please help!
Well if you're trying to show that it is not Cauchy, state what it means for a sequence to not be Cauchy. That is where I would start :)
The sequence isn't Cauchy if there exists an \varepsilon > 0 such that for all N > 0 there exists m, n > 0 such that d(x_m, x_n) \geq \varepsilon.
still stuck
Do you have the theorem that a sequence is Cauchy if and only if it is convergent? And if so, what happens if you suppose ##\lim_{x\rightarrow \infty} = L##?
Yes, I can assume the sequence is Cauchy if and only if it is convergent. The definition of limits that we are using states that \lim_{n \to \infty} x_n = L if and only if
\forall \varepsilon > 0 \, \exists N > 0 \, s.t. \, \forall n > N \quad d(L, x_n) < \varepsilon.
Now can I somehow use the fact that x_n is increasing to say that d(L, x_n) is always increasing? And hence it is greater than or equal to \varepsilon for some n?
It's easier than that. If the sequence has a limit, what happens if you take the limit of both sides of your recursion?
The limit of both sides of the recurrence should then equal the same thing, namely L. Then I would have that
\lim_{n \to \infty} x_{n + 1} = \lim_{n \to \infty} x_n + \frac{1}{x_n^2} = L + \lim_{n \to \infty} \frac{1}{x_n^2} = L.
Doesn't this simply prove that \lim_{n \to \infty} \frac{1}{x_n^2} = 0?
But then doesn't this imply \lim_{n \to \infty} x_n^2 = \infty? completing the problem?
Can that second limit be 0 while the first limit exists? Is there a number L such that 1/L^2=0?
Exactly. Thank you LCKurtz for your patience! :)
  • · Replies 17 ·
  • · Replies 28 ·
