Proving trigonometric identities in converse
8 replies · 2K views · last reply
sooyong94
If ##\sec x-\csc x=\pm p##, show that
##p^{2} \sin^2 2x +4\sin 2x-4=0##
Show conversely that if ##p^{2} \sin^2 2x +4\sin 2x-4=0##, then ##\sec x-\csc x## is equal to +p and -p.
Find, to the nearest minute, the two values of x in the range of 0 to 360 degrees, the equation
##\sec x-\csc x=(1/2) (√5)##
Double angle formula
I have proved the above formula by squaring both sides and rewriting them as sines and cosines. Now how do I prove it backwards? I tried dividing both sides by ##\sin^2 2x## and it doesn't really help much.
Have you tried simply reversing the steps of your first proof? What goes wrong? Please post your working as far as you get.
I did worked until here:
##\frac{4}{\sin 2x} (\frac{1}{\sin 2x}-1)=p^{2}##
and used the double angle formula, but I got this:
##\csc^2 x \sec^2 x - 2\csc x \sec x=p^{2}##
Right so far. If you compare that with the equation you're trying to get to, what equality do you need to make them the same?
I have managed to proved that conversely. :D
Now I need to solve for x for that equation... When I substituted p=1/2 sqrt(5) into the equation, I have
##5\sin^2 2x+16 \sin 2x-16=0##
Then I finally arrived at ##\sin 2x=\frac{4}{5}##. The problem is I have 4 solutions, instead of 2. :confused:
That's right. From the second part, you proved the solutions of the quadratic equation satisfy sec x - csc x = plus or minus p.
So you have to check which solutions are for +p and which are for -p.
So all I have to do is to substitute them back?
Yes. Always a good check on the answer anyway.
