Proving x^2-c^2*t^2 invariance
  • Level: Graduate
  • Thread starter Thread starter durand
    Invariance
9 replies · 7K views · last reply
durand
How do you prove x2-c2t2 is invariant under the lorentz transformations given that;
Left-brace system of four Lorentz transformation equations: t' = γ(t − vx/c²), x' = γ(x − vt), y' = y, z' = z.
Ive tried the obvious replacing x and t with x' and t' but i still can't get it to drop out :(
In x'^2 - ct'^2, replace x' and t' be the expressions that you gave in the original post, and factor x^2 and t^2 out of terms in which they occur.
Try again. I just worked it out and found that c2t2-x2=c2t'2-x'2.
You need to prove that
[tex](x^{\prime})^2 - c^2 (t^{\prime})^2 = x^2 - c^2 t^2[/tex]
After substituting the Lorentz transformation on the left side, everything should eventually cancel out.
Thanks everyone! I didn't see that gamma could be taken out of the equation and cancelled. It works now :D
What you've done is a special case, in the general case, x^2-(ct)^2 is a constant and gamma does not cancel out, the calc is a bit rigorous then, you need to differentiate and substitute v
Oops, mistake.No differentiation.The invariance yields directly by substituting LT.
I differentiated x^2-(ct)^2=k and substituted v , but that's again a special case when v is the velocity of the object in the unprimed frame
Mmm, ok. I think I might be doing that next semester at uni.
