Pruning a set of matrices (easy)
  • Thread starter Thread starter sid9221
    Matrices Set
2 replies · 3K views · last reply
sid9221
http://dl.dropbox.com/u/33103477/prune.png
I am unsure if the the answer is:
[tex]{\begin{pmatrix}<br /> 2 & 1 \\ <br /> 5 & 1<br /> \end{pmatrix}},<br /> {\begin{pmatrix}<br /> 3 & -1 \\ <br /> 7 & 4<br /> \end{pmatrix}}[/tex]
or
[tex]{\begin{pmatrix}<br /> 2 & 1 \\ <br /> 5 & 1<br /> \end{pmatrix}},<br /> {\begin{pmatrix}<br /> 3 & -1 \\ <br /> 7 & 4<br /> \end{pmatrix}},<br /> {\begin{pmatrix}<br /> 2 & 7 \\ <br /> -4 & 1<br /> \end{pmatrix}}[/tex]
I'm pretty sure it's the second one but am a bit confused about when the algorithm stops.
Can someone confirm the answer ?
or
I have never encountered the word prune, but by context, I believe it is saying X is linearly dependent and you want to make a set Y (lin ind) from X that spans ##M_{2,2}## as well.
If that is the case, you just need to verify that none of the matrices in your 3 set are linearly dependent to the other two. If that is the case, then the 3 matrix set is correct.
or
Lay them out as 4-dimensional vectors, then look for a subset that generates the whole span. In other words, start with the vectors
[tex]\begin{array}{l}v_1 = [2,1,5,1] \\v_2 = [3,-1,7,4] \\ v_3 = [5,-5,11,10] \\<br /> v_4 = [2,7 -4,1]\end{array}[/tex] Obviously, [itex]v_1, v_2[/itex] are linearly independent.
Are the three vectors [itex]v_1, v_2, v_3[/itex] linearly independent? If not, [itex]v_3[/itex] is in the span of [itex]v_1, v_2.[/itex] If they are linearly independent, throw in [itex]v_4[/itex] and continue the test.
Note: you can do it all in one step, just by doing row operations on the 4x4 matrix with rows v_i. Basically, you are looking for solutions of the 4x4 linear system [itex]c_1 v_1 + c_2 v_2 + c_3 v_3 + c_4 v_4 = 0.[/itex]
RGV
