Finding A in Non-Square Matrices: Pseudo Inverse vs Gradient Search
The discussion centers on finding matrix A from the equation C = A*B, where A, B, and C are non-square matrices. It is established that if the number of equations (m*k) is greater than or equal to the number of unknowns (m*n), a unique solution for A exists, allowing the use of the pseudo-inverse of B. Specifically, A can be expressed as A = C*pinv(B) when k ≥ n. Conversely, if k < n, a unique solution does not exist, necessitating the use of gradient search or statistical methods to identify potential candidates for A. The uniqueness of A is confirmed only under specific conditions related to the dimensions of the matrices involved.
umut_caglar
Hi everybody
I have a question that I have a guess for the answer but I want to be sure
I have an identity
C=A*B
where A,B,C are matrices and in general they are not square
is there a way to find A in terms of B and C by using pseudo inverse matrix or using pseudo inverse might help me in any ways for finding A.
my guess is: 'No, pseudo matrix inverse will not help in anyway'
If pseudo inverse will not work I am planning to do a gradient search for finding the entries of A (do you have any better option?)
If possible say some words about the uniqueness problem. for given A and B, C is unique, but for given B and C, is A unique
Thanks for the help
Hi
I found solution to my problem, let me share it in case someone else might need it;
lets assume C=A*B
and A, B, C are matrices with dimensions $$ A_{(m,n)}, B_{(n,k)}, C_{(m,k)} $$
Assume we are trying to find A for given B and C
Then the number of equations we have is m*k, one equation for each entry of C matrix
The number of unknowns are m*n, each entry in the A matrix is an unknown
So if number of equations is greater then or equal to the number of unknowns then there is a unique solution. In other words if m*k \geq m*n or simply k \geq n then there is a unique solution.
If there is a unique solution then
C=A*B can be re written as A=C*pinv(B)
where pinv stands for 'pseudo inverse'
if there is no unique solution; i.e k&lt;n, then one need to go to gradient search and statistical methods to find possible candidates for A matrix
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 34 ·
  • · Replies 33 ·
