Pulley-Block-Spring System: Understanding the Forces Acting on a Hanging Block
The discussion centers on understanding the forces acting on a pulley-block-spring system, particularly regarding the second block's interaction with the spring and tension. Participants emphasize the importance of drawing accurate free body diagrams (FBD) to clarify the forces at play, including tension (T), spring force (kx), and gravitational force (mg). There is confusion about whether the spring force should be considered separately from tension, with some arguing that they are interconnected. The conversation highlights the need for a step-by-step approach in analyzing the system, including writing equations of motion for each block. Overall, the discussion stresses the significance of proper diagramming and clear problem statements in solving physics problems effectively.
Abhimessi10
[/B]
[/B]
In the second question at 5:32,why doesn't the block have a spring force.In FBD of 2nd block it should have been mg-(T+kx)=ma right?
Un-PF format and ambiguous:
"why doesn't the block have a spring force "
there are two blocks. The spring is not attached to the left block.
Abhimessi10 said:
In FBD of 2nd block it should have been T+kx-mg=ma right?
No. Think what it should be when the wire is attached to a fixed point.
Sorry but i don't understand what you mean
Draw the free body diagram of each block. What are the forces on the 15 kg block? What is the net force? Then use Newton's second law to calculate the unknown force. Now mov to the second block and do the same thin.
I am talking about the second question at 5:32
It is still a problem of not drawing a proper force diagram. In the equation which you gave, what is T? What is kx? What is mg, what is its direction? All these will become clear if you draw the FBD.
At 5:32 for me if the second block attached to spring is going down,then spring force and tension should act on the block
1. Why is the second block going down? The diagram shows it on the table.
2. The tension is coming from which object?
The question I'm talking about is at 5:32 which involves a pulley
Sorry. I did not realize that you were talking about a different diagram later in the video. OK.
You are writing two separate forces, T and kx. What is exerting these two forces?
The wire exerts tension ,spring exerts Kx in same direction so FBD for block 2 will be mg-(T+kx)=ma in my opinion
The wire and the spring are not two separate things, and each one is not separately attached to the block. The tension on the block is because of the spring, so T is the same as kx. Both should not appear separately in your equation.
But if the block is going down what is causing the restoring force kx of spring
the weight of the block or the tension ?
Go at it step-by-step. Draw separate FBD for each block and the spring. Then write the equation of motion for each object. Then start looking for answers for your questions. You will see the answers pop out one after the other.
Asking about a question buried 5 minutes into a video is not a reasonable thing to do to our homework helpers. Why not draw your own diagram and spell out the question in the problem statement? What are the relevant equations?
Your attempt at solution should not be another question, but a demonstration of what you've tried so far.
Likes BvU
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 22 ·
