cala
- 194
Hello.
I just came to imagine a "thing" that I'm not able to understand correctly, so maybe you can help me.
Imagine a high voltage source, and a circuit made of cable capable of handle high currents (with low resistivity) and a load with medium to high resistance (say 10 KOhm)
Now you connect the high voltage source to the rest of the circuit for just a moment, creating a pulse. During that time, there is high current developing on the circuit, and going through the load doing whatever work this sudden burst of current does on the load. When you disconnect, the current dissapears again.
As Oersted experiment showed, when you have current on a cable, you have a magnetic field around it, and if current changes, magnetic field changes as well.
Now imagine that you put a toroidal coil (with core) encircling the cable that goes between one terminal of the the source and one of the load.
When you connect/disconnect the source to the load, the changing current through the cable will be generated just like before, but now we will collect the changing magnetic field generated by the changing current with the toroidal coil, so we will have electric energy on the toroidal coil...
So first question is:
If we put the toroidal coil, we pick energy that we were not picking before from the changing magnetic field surrounding the cable. In that case... Do the presence of the toroidal coil affect the current or the electric conditions on the load of the electric circuit? Or the circuit will behave the same as before, independently of opposing or not to the changing magnetic field generated by the current?
If the answer is that we can make whatever we want with the field generated outside the cable without affecting the electric conditions or current on the electric circuit, then another question arises:
Imagine you add 10 times more cable between the source and the load. This changes resistance just a bit (because load is far more resistive than the cable), but you could encircle the cable with a coil 10 times longer, so pick up almost the same magnetic field, than before... but using a coil surface 10 times bigger! (or you could use 10 coils like the old one and connect them in series or parallel).
I mean, if you can encircle cables carrying current with toroidal coils without affecting the current that is running through them... You can get almost any value you want from the electromagnetic induction caused by the variable magnetic field!
For sure there is something I'm missing, but could you explain it?
Thanks.
Thanks.
