Can 10^n + 1 Be Expressed as a*a*c?
The problem involves proving that the expression 10^n + 1 cannot be represented in the form a*a*c, where n, a, and c are positive integers. The discussion centers around the properties of the expression when divided by 3 and the implications of its factors.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the remainders of 10^n + 1 when divided by 3, leading to various cases for a and c. Questions arise about the validity of these cases and the conclusions drawn from them.
The discussion is ongoing, with participants examining different cases and questioning the assumptions made in the original statement. Some suggest that the statement may not hold as written, while others provide alternative approaches to the problem.
There is a potential ambiguity regarding whether a and c must be strictly less than 10^n + 1, which could affect the proof's validity. Participants are also considering the implications of prime factorization in relation to the expression.
Pythagorean12
Prove that 10^n + 1 cannot be expressed in the form a*a*c, where n,a,c are positive integers.
By considering the reminder of 10^n + 1 when it is devided by 3, I arrived at the conclusion that:
a*a = 3z +1;
c = 3v + 2
for some positive integers z,v.
Here I am stuck, I have no idea how to proceed
a*a = 3z +1;
c = 3v + 2
How did you arrive at this conclusion? You don't show what you got when you divided 10n + 1 by 3.
Let's consider 3 possible cases:
1) a = 3k. This case is impossible, since from equality 10^n + 1 = a*a*c we notice that the remainder, when LHS is divided by 3, is always 2, and the remainder, when RHS is divided by 3, is 0;
2) a = 3k + 1. Then a*a = 9k*k + 6k + 1 - the remainder, when a is divided by 3, is 1
3) a = 3k + 2. Then a*a = 9k*k + 12k + 4 - the remainder, when a is divided by 3, is 1
Hence, a*a can be expressed as a*a = 3z + 1
Now let's consider 3 possible cases for c:
1) c = 3k - this case is impossible due to the same reason explained in case a = 3k.
2) c= 3k + 1. Then:
a*a*c = (3z + 1)(3k + 1) = 9kz + 3z + 3k + 1. Dividing this by 3 gives remainder 1, while dividing 10^n + 1 by 3 gives remainder 2
3) c= 3k + 2. Then:
a*a*c = (3z + 1)(3k + 2)= 9kz + 6z + 3k + 2. Dividing this by 3 gives remainder 2, and dividing 10^n + 1 by 3 gives remainder 2.
Hence, c= 3k + 2.
(The real problem I want to solve is formulated like that:
The repeat of a natural number is obtained by writing it twice in a row (for example, the repeat of 356 is 356356). Is there any number whose repeat is a perfecr square.
Let's denote the n-digit number by b. Then we have:
b*10^n + b = c*c;
b(10^n + 1)= c*c
I have made a little investigation for 10^n + 1:
n
1 10^n + 1=11 - prime number
2 10^n + 1=101 - prime number
3 10^n + 1=1001=7*11*13
4 10^n + 1=10001=73*137
5 10^n + 1=100001=11*9091
6 10^n + 1=1000001=101*9901
7 10^n + 1=10000001=11*909091
8 10^n + 1=100000001=17*5882353
9 10^n + 1=1000000001= 7*11*13*19*52579
Form this, we notice that each prime factor of 10^n + 1 occurs only once. Hence, I have come to the sketch of the proof that no such number whose repeat is a perfecr square exists:
1)10^n + 1 is a prime number.
Then it must be a= e*e(10^n + 1) -> a is a n+1 digit number -> contradiction
2) 10^n + 1 is not a prime number
Each prime factor of 10^n + 1 occur only once (as "deduced form examples above")
I try to prove last statement by contradiction. Let's assume that 10^n + 1 = a*a*c (a*a means that some prime factors occur more that once). The work for this part was described above.
Hence, if this last unproven statement is true, then a = e*e(10^n + 1) -> a is a n+1 digit number -> contradiction.
While this may be an old thread I stumbled across and felt I should add some input.
This statement cannot be proven as it is currently written.
Ex. Assign c the value 10^n + 1. Divide LHS by c. This implies that a^2 = 1 which implies a = 1. Therefore for all n 10^n + 1 can be written as a*a*c.
If it was meant that a and c must be strictly less than 10^n + 1 then the statement can be much more easily proven then the route you were taking.
Start by dividing LHS by c. Then it must be that ( 10^n + 1 ) / c is a perfect square since a is a positive integer. This implies that \sqrt{ 10^n / c + 1 / c } is also an integer. All that's left for you to do is show that for every c < 10^n + 1 , that \sqrt{ 10^n / c + 1 / c } is never an integer value.
Hint: it would suffice to prove that the expression inside the brackets is itself never an integer value for all allowed values of c.
  • · Replies 21 ·
