Pushing at a downward angle with friction
  • Thread starter Thread starter casedogg
    Angle Friction
The discussion centers on calculating the force required for a factory worker to push a 32.0 kg crate at a constant velocity while applying a downward force at a 40° angle. The coefficient of kinetic friction between the crate and the floor is 0.25. The key equations derived include the normal force (Fn = mg + Fy) and the frictional force (fk = 0.25Fn). Ultimately, the required force (F) to maintain constant velocity is determined to be 129.5 N.
  • Understanding of Newton's laws of motion
  • Knowledge of vector decomposition and trigonometric functions
  • Familiarity with the concepts of friction and normal force
  • Basic algebra for solving equations
  • Study vector decomposition techniques in physics
  • Learn about the implications of friction coefficients in mechanical systems
  • Explore advanced applications of Newton's laws in real-world scenarios
  • Investigate the effects of varying angles on force calculations
Students in physics, engineers involved in mechanical design, and anyone interested in understanding the dynamics of forces and motion in practical applications.
casedogg
A factory worker pushes a 32.0 kg crate a distance of 5.0 m along a level floor at constant velocity by pushing horizontally on it. The coefficient of kinetic friction between the crate and floor is 0.25. The factory worker pushes downward at an angle of 40° below the horizontal.
What magnitude of force must the worker apply to move the crate at a constant velocity?
Fn= mg+Fy
fk=.25Fn
Fy=Fsin(40)
I spent a long time trying to figure this out, I know mg=313.6N and i need to add the force of the y component to that to find the normal force, but I don't know how to find Fy, or Fx. If there was no vertical push it would just be 78.4N in the x direction, which equals the force of friction. But with the vertical push it seems like the harder you push, the more friction increases, and thus you need to push harder. I saw other people have had the same question on this forum before, but with different numbers, but they don't help me because people only told them that the vertical push makes the normal force bigger, but I don't know how to calculate the vertical push.
Fn= mg+Fy
fk=.42Fn
Fy=Fsin(40)
I spent a long time trying to figure this out, I know mg=313.6N and i need to add the force of the y component to that to find the normal force, but I don't know how to find Fy, or Fx. If there was no vertical push it would just be 131.712N in the x direction, which equals the force of friction. But with the vertical push it seems like the harder you push, the more friction increases, and thus you need to push harder. I saw other people have had the same question on this forum before, but with different numbers, but they don't help me because people only told them that the vertical push makes the normal force bigger, but I don't know how to calculate the vertical push.
Would you believe that you have already written the equation that gives it to you?
Before I tell you where it is, do you know how to break vectors into components? You use trig. --you know sines and cosines hypotenuses and opposite and adjacent sides and all that good stuff :smile:
Up above you wrote F_y = F sin(40) It seems you knew how to do it all along...
But I don't know what Fy is or F, what I'm trying to find is F, if I could find Fy, Fx, fk or Fn then I would be able to find F
Well, first since the velocity is constant, the acceleration is zero and so the sum of the forces in the x direction is zero. That implies that the frictional force is equal in magnitude to the applied horizontal force or,
f = F cos(40)
But,as you know, the frictional force is also given by
f = \mu_k(mg + Fsin(40) )
You know \mu_k and m and g and you can set those two equations equal and get F.
F=129.5N
Thank You very much!
I had been trying to find two equations like that which equaled each other so I would only have one variable.
