Pushing crates up a frictionless ramp
9 replies · 6K views · last reply
drjohn15
Mario's new additions to the company's standard ramp include two hard nylon rails which run the length of the ramp; the crates which have to be moved will slide along the hard nylon rails with almost no friction. In the space on the ramp which is in between the nylon rails, Mario has installed a special super-grip carpet, which will give the mover great traction as he or she pushes the crates along the rails and up the ramp.
They begin with the ramp in a North-South orientation flat on the lab floor, and they put two crates of equal mass side-by-side at the south end of the ramp. They then use two hydraulic jacks to raise the north end of the ramp to a desired height; one crate is then at the bottom of the ramp (where the ramp intersects with the lab floor) and the other crate is adjacent to the first and just a little higher up along the ramp. We will now refer to the first crate as the "lower crate" and to the second crate as the "upper crate".
Mario knows that most of the company movers will use the ramp to push crates at constant speed, but he wishes to test extreme possibilities, so he plans to push the crates up the ramp with increasing speed. He selects two crates, each of mass 47 kg. The start of his push will be at the bottom of the ramp, and he puts a piece of tape at a point 5.7 m along the ramp (not along the floor) which will mark the endpoint of his hard push; upon arriving at this endpoint, he will "ease up" so that the crates will move at constant speed for the rest of their journey the top of the ramp. Luigi measures the height from the lab floor to the marked endpoint as being 250.8 cm. Luigi also designs a system of two electric eyes connected to a digital timer which will time Mario during his trip from the starting point to the marked endpoint. The size of the selected crates is just right so that Mario will push HORIZONTALLY (parallel to Earth's surface) on the lower crate.
So I know this is lengthy, but I have about 27 questions that have to be answered about this scenario. I'm really just having trouble visualizing this and drawing the free body diagrams.
Any help would be really great! I just need a push in the right direction.
Thanks!
So far I have two different scenarios drawn. The first is where the lower crate is pushed by Mario, and the upper crate gets pushed by the lower crate (one in front of the other).
My other drawings show the lower crate at the bottom of the ramp, and the upper crate to the east of the lower one (side by side) and slightly higher up the ramp.
I don't blame you, the explanation of the positions of the crates is pretty ambiguous. You may email your professor and ask him/her to clarify what is meant by "adjacent to the first and just a little higher up along the ramp."
However based on context I'm lead to assume that it means basically "resting" directly in front of the first crate.
Further, it might help to see the questions you need answered, perhaps a picture so that you don't have to type it all out.
Here are some of the questions asked.
***EDIT, I guessed on the first three questions... ****
  • Screenshot of an online physics homework form with warm-up questions about contacts between two crates and a ramp, followed by parts (a) to (f) on forces when the speed is constant, with answer fields and direction dropdowns.
I attached a picture if what you're diagram SHOULD be. Don't take it as absolute though, I'm still not 100% on the intent here.
The diagrams below are individual diagrams of the boxes, and note that I didn't include all the relevant forces nor did I draw the two boxes as a single object, which you should do.
Hopefully this can get you going!
Let us know if you have anymore specific questions concerning the specific solutions.
  • Whiteboard free-body diagram of two crates A and B on a frictionless incline of length l = 5.7 m and height h = 2.508 m, with force F_my applied to A and F_A on B labelled, plus individual force diagrams for each crate showing F_N, mg and friction.
So I managed to find all of the quantities for the crates at constant speed. But now their throwing in some acceleration and I'm kind of lost as to how to approach this.
I've attached some of the questions that have already been asked and also the questions that I'm having trouble with.
Thanks!
  • Screenshot of an online homework form with answer boxes for parts (a) through (j) about forces on two crates pushed up a ramp; several answers are marked correct and one is marked incorrect.
drjohn15: how did you find the parts of the first part I am stuck on this part now?
Apologies for the delayed response. In having trouble viewing those questions but you asked about acceleration, so I can say this: F=MA, if you've found the force mass is given, acceleration easily follows. Just keep in mind the force and acceleration are vectors and the acceleration is ALWAYS in the direction of the Force and vice versa. I'll take a better look at the questoons later this evening and have a more specified response if you need it.
I know this isn't my post but I have the exact same problem just with different numbers...
How do you find the normal force on the lower crate since it isn't the same as the upper crate because of Mario pushing on the crate.
I took Mario's pushing force and subtracted the force on the lower crate by the upper crate and that gave me (I think) the x component of the normal force.
Am I on the right track?
