PV Diagrams (Curve v. Straight)
  • Thread starter Thread starter jaysonr
    Diagrams
The discussion revolves around understanding the characteristics of PV diagrams, specifically the differences between curved and straight lines in these diagrams. Participants explore the implications of temperature, pressure, and volume in the context of ideal gases and thermodynamic processes.
  • Participants question the conditions under which lines on a PV diagram are curved versus straight, with references to isothermal and adiabatic processes. There are discussions about the relationships between pressure, volume, and temperature, and how these affect the shape of the lines.
Some participants have provided general guidelines for determining the nature of the lines in PV diagrams, while others seek clarification on specific examples and underlying assumptions. The conversation reflects a mix of exploratory questions and attempts to clarify concepts without reaching a definitive conclusion.
There is an emphasis on ideal gas behavior and the assumption that no gas enters or leaves the system. Participants are also navigating the implications of constant temperature and pressure in their discussions.
jaysonr
Why are some lines on a PV digram curved and some lines are straight?
Be more specific. Give an example of a PV diagram you don't understand.
Assuming that the no gas enters or leaves, there's a third relevant variable: temperature. If you heat something, it will either expand, increase in pressure, or a little of both.
edit: There are only these 3 variables if nothing enters or leaves the system if the gas is assumed to be ideal (the molecules neither take up space nor attract each other).
That still doesn't explain why the state at (Po, To) is curved when it goes to state (0.5Po, 2Vo). If it's directly proportional, shouldn't it be a decreasing straight line slope?
Pressure and temperature are not directly proportional. PV = constant if the temperature is constant.
So how do you know if one of the lines need to be straight or need to be curved?
You can just make a back-of-the-envelope graph. For example if the temperature is constant (which would be expected if everything happens slowly and there's poor insulation) you can assume PV = 1 (although any constant would do) and then make a rough graph with P being 1/4, 1/2, 1, 2, and 4 (V would be the inverse).
That's a pretty general question, so here is a general answer.
If the line is curved, then a problem statement will either:
(1) tell you that the process is isothermal
(2) tell you that the process is adiabatic
(3) present you with a diagram that shows a curved line
or (4) provide some other information that allows you to conclude that the line is curved.
If the line is straight, then a problem statement will either:
(1) tell you that the process is at constant pressure (for a horizontal line)
(2) tell you that the process is at constant volume (for a vertical line)
(3) present you with a diagram that shows a straight line (could be horizontal, vertical, or slanted)
or (4) provide some other information that allows you to conclude that the line is straight
That is so much clearer. Thank you!
  • · Replies 16 ·
  • · Replies 16 ·
