Python:Reading (int,float,comp,bool) from file
  • Context: Python
  • Thread starter Thread starter Raghav Gupta
    File
4 replies · 7K views
Raghav Gupta
Read a comma separated numeric (int, float, comp, bool) values from a file and store each
comma separated value in a list[/B]. Sort the list (without using in-built sort/sorted function)
and write it to output file in comma separated format.
In my attempt I am not able to do the bold part in the question. That is if float value is there in file then it cannot be typecasted to int. How do I typecast with conditions?
NA
Python:
f=open("qwerty.txt","r")
y=[]
for line in f:
    x=line.split(',')
    for val in x:
       y.append(int(val))  # Here if float is stored in file then it cannot be typecasted to int.
for i in range(len(y)-1):    # Doing bubble sort
    for j in range(len(y)-i-1):
        if y[j]>y[j+1]:
            y[j],y[j+1]=y[j+1],y[j]
f.close()
f=open("output.txt","w")
f.write(str(y)[1:-1])
f.close()
NA
Python:
y=[]
for line in f:
    x=line.split(',')
    for val in x:
        if y[j]>y[j+1]:
f.close()
f.close()
Is the idea just to read values from the file and store them in a list? If so, why do you need to cast a floating point value to an integer value? The problem description you have doesn't mention doing this.
But we have to sort, so we have to convert it into numeric type.
EDIT: Ok, so we can compare them as strings only. It would compare lexicographically based on ASCII values but if we store them in file again, it is stored something like this-
'1' , '2+j', '3.5', '4', 'FALSE', 'TRUE'
This is storing the list contents in string format. I want output like this-
1, 2+j, 3.5, 4, FALSE, TRUE
without quotes
For that I have to typecast finally?
Raghav Gupta said:
Python:
y=[]
for line in f:
    x=line.split(',')
    for val in x:
The problem is that the text file doesn't contain floats or integers or complex numbers -- it contains text. Your variable x is a list that contains strings. For example, if the first line of the input file is 3.5, 2, true, the list x will look like ['3.5', '2', 'true'].
The reason that int(val) throws an exception (ValueError) is that int() can't be used on strings. For the same reason, float(), bool(), and complex() will fail when applied to strings.
What you need to do for each value you get from the file is figure out if it's a complex or float or integer or Boolean. One way to do this is to have four other variables, with each initialized to a value of one of these four types (complex, float, integer, Boolean).
Python:
v_cplex = 1+2j
v_float = 1.5
v_int = 1
v_bool = True
There's nothing special about the initializations I did above. I just want four variables with each of a specific type.
For a given val, try assigning it to each of the above variables. If you assign val to f_float, for example, and get an error (ValueError), you know that val isn't a float value. After you determine that val is, say, a float, append v_float to your list y.
Edit: One more thing. If you write the various values to a list as numbers, you won't be able to sort them, as complex numbers aren't comparable to real variables (such as int, float, bool).
