QM: Sum of projection operators = identity operator?
The discussion revolves around the calculation of the sum of projection operators for an observable represented by the matrix K. The eigenvectors corresponding to the eigenvalues 1 and -1 are identified, and their outer products are computed, resulting in matrices that sum to 2 times the identity operator. A key point raised is the necessity of normalizing the eigenvectors to unit vectors, which would correct the sum to equal the identity operator. The normalization involves multiplying the eigenvectors by 1/√2. Proper normalization is essential for ensuring the projection operators correctly represent the identity operator in quantum mechanics.
Simfish
So we have an observable K = \begin{bmatrix} 0 & -i \\ -i & 0 \end{bmatrix}
and its eigenvectors are v1 = (-i, 1)T and v2 = (i, 1)T corresponding to eigenvalues 1 and -1, respectively.
Now if we take the outer products, we get these...
|1><1| = (-i, 1)T*(i, 1) = \begin{bmatrix} 1 &amp; -i \\ i &amp; 1 \end{bmatrix}
|-1><-1| = (i, 1)T*(-i, 1) = \begin{bmatrix} 1 &amp; i \\ -i &amp; 1 \end{bmatrix}
Then we add them and they sum up to form 2*(identity operator).
But isn't it supposed to sum up to the identity operator? What's wrong, or what happened?
Hi Simfish! :wink:
Simfish said:
… and its eigenvectors are v1 = (-i, 1)T and v2 = (i, 1)T
Don't you need to normalise them (to unit vectors), by multiplying by 1/√2 ? :smile:
Hi. :) Okay, good idea. Thanks!
(a) The polarisation pattern is elliptical with maximum (1,1) and minimum (-1,-1), and anticlockwise in direction. (b) I know the solution is a quarter-wave plate oriented π/4, and half-wave plate at π/16, but don't understand how to reach there. I've obtained the polarisation vector (cos π/8, isin π/8) so far. I can't find much online guidance or textbook material working through this topic, so I'd appreciate any help I can get. Also, if anyone could let me know where I can get more...
  • · Replies 33 ·
  • · Replies 18 ·
