Quadratic inequality-interval notation
To solve the quadratic inequality 2x^2 < -x + 10, first set it to zero, resulting in the equation 2x^2 + x - 10 = 0. The solutions to this equation provide boundaries for the intervals to test. After finding the roots, test values from three intervals: less than the smaller root, between the roots, and greater than the larger root. The results will determine which intervals satisfy the original inequality, allowing for the solution to be expressed in interval notation. The process effectively identifies the solution set for the inequality.
Torshi
quadratic inequality--interval notation..
2x^2<-x+10
Solve inequality and put into interval notation
interval notation
I don't even know where to start. I set it equal to zero -2x^2-x+10=0
It's fine to start by solving the corresponding equation. The solutions of the equation become "boundaries," if you will, of sets of numbers that are solutions to the inequality. Suppose there are two solutions, a & b, with a < b. Then you would have 3 potential range of numbers to test.
Pick a value less than a and test into the original inequality. If the result is a true statement, then x < a would be in the solution set.
Then pick a number between a and b and test. If it works, then a < x < b is in the solution set.
Finally, pick a number in greater than b. If it works, then x > b is in the solution set.
