Qualitative: A Uniformly Charged Cylinder
  • Thread starter Thread starter tristan3214
    Charged Cylinder
The discussion centers on the electric field components around a uniformly charged cylinder with charge density sigma and radius a, as described in Griffiths' Electromagnetism textbook. The key conclusion is that outside a very long cylinder, the electric field only has a radial (s) component due to symmetry, and no axial (z) component exists. The reasoning is based on the uniform charge distribution and the infinite length of the cylinder, which negates the influence of end effects. When considering finite lengths, the z-component may emerge, but this is outside the scope of the 'very long' assumption.
  • Understanding of electric fields and charge distributions
  • Familiarity with cylindrical coordinates (s, phi, z)
  • Knowledge of symmetry arguments in electrostatics
  • Basic concepts of electric field lines and their behavior
  • Study the concept of electric field symmetry in cylindrical geometries
  • Learn about the mathematical derivation of electric fields from charge distributions
  • Explore the implications of finite versus infinite charge distributions
  • Investigate the behavior of electric fields near charged objects using Gauss's Law
Students of electromagnetism, physics educators, and anyone seeking to deepen their understanding of electric fields around charged cylinders.
tristan3214
This is just a qualitative question that is along side my main lecture with Griffiths EM book.
Basically we have a very long cylinder with charge density sigma and radius a along the z axis. This is mostly beside the point and is just to setup the question. The question asks that we are in a situation where a student thinks there are components of the E-field in every direction (for reference we use (s, phi, z) for the coordinates) outside the cylinder. It then asks you to explain each component of why you can or can't have them in, essentially, laymen terms (which I assume to be likely symmetry arguments). The s and phi I think I can do but the z I am having trouble discerning how symmetry says we can't have a z component.
To start I know the electric field is only supposed to depend on the s component. However, I am confused about why we can't put an E-field on top of the cylinder and it thus would have components in this direction. I should mention that the cylinder is supposed to be very long which I am not sure if that means we don't care about the caps. In which case then if we put a test charge outside the cylinder then we move the cylinder up and down the test charge will not be affected because it looks exactly the same. However, let's say it is of length L how would this affect the answer exactly?
In this context, 'very long' means you don't have to consider end-effects. I think you get the picture. And indeed, by the time one of the ends does need to be taken into consideration, there is a z-component of the field emerging. If you go far enough, the very long cylinder starts to look like a point charge more and more and field goes towards a point-charge field. But then the book wouldn't have mentioned 'very long'.
Thanks for the reply.
  • · Replies 16 ·
  • · Replies 26 ·
